Old 08-28-2013, 09:10 PM
taco_combo taco_combo is offline
Mein Auto: 2001 BMW 740I sport
my door handle broke off...yep snapped off
it was loose and poof it snapped righr off so I have to open the door from the back seat and reach forward.
will an e39 door handle fit on my e38?
http://www.ebay.com/itm/BMW-E39-5-Se...01735b&vxp=mtr
Old 08-29-2013, 09:19 AM
bigd503 bigd503 is offline
Mein Auto: 2000 bmw 740i
Re: my door handle broke off...yep snapped off
I have ripped off my driver door handle like 5 times the e38 have heavy doors look on ebay or rockauto.com for new or used door handle
Sent from my SCH-R530C using BimmerApp mobile app
Old 08-29-2013, 07:33 PM
JasonSC540ia JasonSC540ia is offline
Mein Auto: 1999 740i
I did that. I took the door handle off the rear door and put it on the front untill I got the new one in. Pretty easy. Took like 30mins to swap back to front.
Old 09-01-2013, 11:35 PM
I just bought a new door handle (silver front) on ebay for $45.00
Old 09-02-2013, 05:45 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
You do know that the e38 uses 2 different door handles depending on build date...the early e38s (pre-facelift) aren't lit...the 99 model year up handles are lit.
If you check the part database like realoem.com (if you haven't already)...you'll probably see multiple part nbrs based on build date. And while there...you can also cross reference to see if the e39 uses the same handles.
Hopefully you purchased an illuminated door handle for the facelift e38. I always recommend shopping by first looking up the BMW 11 digit part nbr based on your cars VIN...then searching online using that 11 digit part nbr. This separates the sellers that are selling parts willy nilly from the ones that have referenced the parts they are selling...enough so that they can identify which BMW part they have and the vehicles BMW uses them on.
Q {BMW CCA Member #191509}
(SOLD)
Old 09-06-2013, 10:37 PM
I hope I guessed right - I will find out this week
"This one has the fiber optic light, which is under the lever," from ebay add
HTML code is Off
