Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X3 F25 (2011 - current)
The latest X3 brings added style and new features to the BMW's mid-sized SUV. Talk about the BMW F25 X3 with other X3 owners now!
Old 08-29-2013, 11:13 AM
billyk billyk is offline
Mein Auto: F25 X3 35i M sport
better brake?
Hi,
Changing from three 3-series coupe and sedans to a F25 X3, I feel like the brake is "weak" relatively on the F25. After about two weeks and 600 miles of driving, there were a couple of instances got to my nerves when it took longer to stop than I expected. I understand the car is way heavier than the last E90 with the same HP output. I don't expect F25 to brake as good as the E90. However I want more brake power.
Did anyone change anything and getting good experience on brake feel or brake performance?
Fluid or pads?
Will
2005 E46 ZHP coupe
2008 E92 ED+PCD
2011 E90 M sport ED
2014 F25 M sport
2017 F25 M Sport
Old 08-29-2013, 01:42 PM
Drewsky's Avatar
Drewsky Drewsky is offline
Mein Auto: '14 X3 35i-M Space Grey
Originally Posted by billyk View Post
Hi,
Fluid or pads?
Will
Hi, I also came from an e46 330, so I know what you mean about the difference. I can say that the brakes took a good amount of time for them to be fully effective: like over 1500 miles. I even did a bedding-in procedure when I first got my X3 and the brakes still were a little wishy-washy until some miles got run up.
That said, I can say that the first undercarriage upgrade I make will be some stronger steel-braided brake lines to help tighten up braking, and then when the time comes maybe a different brake pad compound, but I have no urgency for swapping out the pads. I've done an emergency brake once and I did get four wheels of ABS so they worked, the feel is just mushy.
Old 08-29-2013, 03:30 PM
The X Men The X Men is online now
Mein Auto: 2013 X3 35i
I think you answer your own question, the X3 is much heavier than the E90. I have a F25 and a F10, the 535i is a bit heavier than the X3 but the 535i brakes much better than the X3. That's probably due to more pistons in the front brakes. You can always buy a big brake kit with more cylinders, which should help with the braking power. If you don't mind brake dust, you can always get a set of semi metallic pad to increase the braking performance as well.
Old 08-29-2013, 08:21 PM
02420X3 02420X3 is offline
Mein Auto: 2011 X3 35i
If you do mind Brake Dust you're either not a BMW owner, or you have great wheel-cleaning skills, LOL.
Old 08-30-2013, 01:24 AM
RhoXS RhoXS is offline
Mein Auto: Z3 & X3
I replaced the brakes on my 2002 3.0i Z3 a number of times over the past 11 years and 145,000 miles. I use Akebono ceramic pads and Brembo rotors. This vehicle came with really outstanding brakes and this combination does not appear to have effected brake performance in any way. In addition, there is no longer a dust problem.
Old 08-30-2013, 06:49 AM
Usually, when I replace semi-metallic pads with ceramic, I loose that initial bite when braking.
Old 08-30-2013, 04:47 PM
gfeiner's Avatar
gfeiner gfeiner is offline
Mein Auto: 2012 X3 xDrive35i
better brake?
That is my experience as well. Ceramic pads dont perform well when cold. It's most noticeable for the first few stops during winter until the pads warm up
Old 09-05-2013, 10:48 AM
Zuger Zuger is offline
Mein Auto: 2012 28i X3
I agree with the braking of the X3, I find it too soft/spongy, they do not seem to grab quickly. I thought it was a problem and I brought my X3 in for service but the dealer said they were ok and it was normal. I guess I will have to live with it, however I do not get any brake dust on my wheels which is good, not like my wife`s Mini Cooper S which has fantastic grabing brakes but a lot of brake dust!
2012 X3 28i space grey, black nevada leather, premium package, technology package
2010 Mini Cooper S
Old 09-05-2013, 11:12 AM
I think that is more of a function of the X3's braking system than the pads itself. My 535i's brake has a bit more of a bite to it on the top end, the pedal also seems more linear than the X3's. The X3 seems to be more on the bottom end. The 535i's brake pads seem to have the same material as the X3, no brake dust.
Old 09-05-2013, 12:48 PM
Tangsta Tangsta is offline
Mein Auto: Alpine White F25 35i
It always seems to be the E series converts that complain about the X3 brakes.
For me, the X3 is my first BMW and I feel the brakes are more than adequate... I've also driven a few E46s before, and being used to my Acura and Mazda at the time, I felt the BMW brakes were really touchy and sensitive - in fact, I almost hit a parking curb when I switched back to my Acura because I was feathering the brake after getting used to the 3-series.
Just a matter of what you're used to ... you have to use more of the X3 brake pedal.
Now I wonder if it's an X3 thing, or if BMW is numbing their product line altogether with the F-series (electric power steering being the start of it).
