Old 08-29-2013, 02:10 PM
SNORTH_335 SNORTH_335 is offline
Mein Auto: 2011 BMW 335i
New to the forum! Have a quick question!
Wattup guys, my name is Steven, I just bought a CPO 2011 335i M Sport. The car is loaded, Nav, Heated Seats, Etc. My girlfriend has a 2011 328i, her car will allow her to stream Audio via bluetooth, I can not seem to find this option on my car...? I think I have the same packages as she has and then some. Do all Nav cars have the ability to do this? Thanks ahead of time!!
Old 08-30-2013, 07:33 PM
AndrewHA AndrewHA is offline
Mein Auto: BMW 335xi Coupe
My 2008 335xi can't do this. I think you need an update on your iDrive.
Old 09-03-2013, 07:54 AM
I'm assuming the dealer will do this? Will that be covered under extended warranty?
Old 09-03-2013, 10:07 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
Ignore this post... Can't delete.
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 09-03-2013, 12:06 PM
Mein Auto: '06 AW 330xi
I believe you need the COMBOX option to stream via bluetooth but I maybe wrong. If the option is not in your car, you need a new module, then programming. This isn't a simple software upgrade. Your car's bluetooth module needs to have the AD2P bluetooth profile which is different from the hands free profile.
However, to my knowledge, COMBOX retrofits are not officially supported by BMW, so your local dealer will not code the COMBOX unit into your car. You will need to find someone who codes, such as myself, to retrofit the module.
A much easier option is to use an adapter like the one below. I use this in my car and it works with the car's bluetooth for handsfree. My iPhone handles calls and pauses music automatically. The unit also connects when you turn on the ignition (if you're using a switched power source, which you should). The only downside is that you cannot control your iPhone through the car. I find controlling the music via my phone is much easier anyway. Especially since my iPhone is jailbroken and I use the app "music controls" to control my music apps. It allows me to control volume, skip, go back, pause, play etc with touch gestures, even with the phone in "sleep" mode, screen off.
http://www.amazon.com/BlackBerry-Rem...stereo+gateway
Old 09-03-2013, 12:57 PM
Wow!! Thanks man, I see that the link you sent me is for a blackberry? Will it cross for an iPhone 5? I know you said that you used yours with an iPhone, so i'm guessing it does? Thanks for the information by the way!!
2011 335i M Sport
Old 09-03-2013, 01:04 PM
Yes it works with any bluetooth phone with AD2P, which is pretty much any phone with bluetooth made within the past few years.
No problem.
You do need to get a cigg lighter adapter for power. Those cheap iphone chargers work fine. I use the belkin one because it's low profile. I've gotten them for 1 cent on amazon. Seriously, 1 cent. Those deals may not be around anymore but look around. You'll also need the usb (for power) and aux cable (for sound). I got short 3" ones so it's all tidy in my armrest and then double sided tapped the adapter to the back of the armrest compartment.
Old 09-03-2013, 01:05 PM
haha $5 for shipping I would order like 5 or 6 and keep them around. Great for other cars, "lend" to friends (you know you won't get it back lol), etc
http://www.amazon.com/Belkin-Micro-A...sb+car+adapter
Old 09-03-2013, 01:08 PM
Haha, thanks again man, Im ordering both! If I have any problems ill DM you!
2011 335i M Sport
