E34 (1989 - 1995)
Old 08-31-2013, 07:36 AM
Nebmwowner Nebmwowner is offline
Mein Auto: 1995 BMW 520i
Overheating! Electric cooling fan in front of radiator not working.
Hello! I have a 1995 BMW 520i. It's been overheating for the last couple weeks now. I've replaced my fan clutch and my thermostat. My cooling fan in front of my radiator does not work. It works when i jump the wires but only on high. I've researched it and apparently i need a new resistor. Another thing the car oveheats to red but the car stays in the middle and below middle when the defrost is on. So i can drive my car no problem with defrost on but it gets pretty hot in the middle of the day when the defrost is blowing scolding heat. So i've ordered the resistor. I was just hoping someone can give me any other options for my problem. Thank you ahead of time! This is my first time owning a european car and also my first thread!
Old 08-31-2013, 05:48 PM
travs750li travs750li is offline
Mein Auto: 750Li
You replaced the thermostat and water pump. Got to make sure you bleed the system. This is a very common problem for our series. I have dealt with the same thing. I replaced head gasket, thermostat, and water pump, and hoses. I never bled the system and it over heated again. Once I bled the system, good to go.
Old 08-31-2013, 11:57 PM
I didnt replace the water pump yet. I've been trying to bleed the system. This is the way i've been doing it. i top off the coolant and close the radiator cap go drive it around town get the temp up and bring it to my garage which has a bit of an incline and open the bleeder valve on it until i see no bubbles come out of it while the vehicle is running. Is that the best way or even the right way to bleed it? How many times should it take? i've heard of the water pumps having a plastic impellar inside them. You think i should take my water pump and take a look on the inside and see if it's destroyed?
Old 09-01-2013, 08:34 PM
ThoreauHD ThoreauHD is offline
Mein Auto: 02/1994 530i 8cylinder
The aux fan resistor is $20 at bavauto. Easy to replace.
Old 09-03-2013, 03:07 PM
BMWFatherFigure's Avatar
Old School
Check the switch for the fan on the radiator as well. You dont have to drive to bleed. As long as it is hot (working temp) you can be stationary with the bleed valve open. Next thing would be radiator flow (blocked core) tests.
Current:
E38 Parts Car
Previous:
Old 09-06-2013, 12:47 PM
YESSSSSSSSSSSSSSSS!!!!!!!!!!!!!!!!!!!!! So finally!!!!!!!!!!!!!!!!!!!!!!!!!! The water pump!!!!!!!!!!!!!!!!!!!!!!!! The stupid plastic impellar wouldn't even come out! I had to use needle nose and my hands and a standard to get the thing out! But at least I know the water pump, fan clutch, and thermostat are 100% good still! =) Thank you so much for commenting on my thread! You guys rock!
