The X5 SAV Forum
Old 08-31-2013, 01:50 PM
krueger krueger is offline
Mein Auto: 2005 X5
2005 X5 without air suspension??
Vehicle info:
2005 X5 3.0i, Manual Transmission, about 96K miles.
I am working on replacing the rear upper control arm and rear ball joints on my 2005 X5. I had the famous inside of the tires wearing big time. I was surprised when I started tearing it apart to find coil springs in the rear instead of air bags.
I looked online and see they make kits. I just bought this used about 5 months ago. To be honest I was looking for an 04 to avoid the air suspension, but compressing the springs to replace the rear ball joints is a major pain in the @#$.
So two questions. One could the inside tire wear be due to a poor conversion from air to springs? Second did they make any 2005 X5 without air suspensions. If it was a conversion who ever did it had the computer updated it looks like since I don't have any warning lights.
Also if anyone has any tricks for compressing the springs I would love to hear about that.
Thanks in advance.
Old 08-31-2013, 08:27 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
The answer to that question is as close as the part database:
http://www.realoem.com/bmw/partgrp.d...45&hg=33&fg=45
BTW, you can help us to help you better if you add WHICH X5 you have...there are 3 different models for the 2005 model year here in the USA....which means different engines, transmissions, option pkgs, etc:
Q {BMW CCA Member #191509}
(SOLD)
Old 08-31-2013, 08:30 PM
Mein Auto: 2005 X5
Thanks, great idea ,
I also updated original post and added more info about the car. Thanks again.
Jeff
rear ball joint, rear control arm, rear springs
