Slipping backwards in park (stick) - Bimmerfest - BMW Forums
Old 08-31-2013, 05:11 PM
Landshark 328 Landshark 328 is offline
Mein Auto: 328is
Hey guys, just upgraded to a 335i Msport with 26k miles. Loving it but have noticed one strange thing in the first week.
When parking on a hill and leaving it in first (its a manual) the car slips backwards. Once the car is off and left in gear it slips backwards about 3-4 inches. Then in 5 seconds or so it slips a few inches again. It has a perfect rhythm to the movement (slip-pause-slip-pause-slip ...)
Does anyone else have this issue or know what causes it?
EW///
Old 08-31-2013, 05:44 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
It can really only be 2 things since leaving it in first is just locking the wheels to the engine, so either the clutch is slipping or the engine is actually turning over. If the engine is turning over, then either the hill is extremely steep causing enough force to overcome compression, or the car is leaking compression past the valves slowly allowing the engine to turn over a little and the car can move.
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 08-31-2013, 06:48 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
This. A slipping clutch would result in a steadier roll. Also, very unlikely at only 26k miles.
OP: Did you notice that leather-wrapped lever with a button on the end, behind and to the left of the gearshift? Ever wonder about its purpose? (Hint: Ignoring it is the cause. )
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 08-31-2013, 07:15 PM
Yes, leaving a car in gear should not be considered safe without the parking brake on!
Old 08-31-2013, 09:06 PM
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
There is this mysterious and semi-mythical device called a "Parking Brake".
We can only speculate as to its functions, but some of the wilder theories suggest that it might have once been used while a vehicle is parked.
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
Old 08-31-2013, 10:23 PM
#propaganda #propaganda is offline
Mein Auto: 2007 335i sedan base
^+1
Old 09-01-2013, 06:51 PM
Mein Auto: 328is
In my truck I can always leave it in gear and it wouldn't go anywhere.
It was still moving with the ebrake on. I might have to rebuild the ebrake over time
EW///
Old 09-01-2013, 07:19 PM
TXFred TXFred is offline
Mein Auto: 2008 335i Convertible
This may help.
http://www.m3post.com/forums/showthread.php?t=453084
Any idiot can be fast in a straight line. The corners are what separates the drivers from the commuters.
Old 09-02-2013, 08:45 AM
Pilgrim's Avatar
Car guy since 1968
Dang! That's not good. Time to get that parking brake (no longer called an "emergency brake", although I get where you're coming from) snugged up and working.
Seriously, every drivetrain has some slack, and when parking a stick transmission in gear, it's normal for the car to be able to move a bit. if you're on a hill, you always select low or re verse, and turn tires so they contact the curb - which also implies that you're a competent driver and can park within a foot of the curb or less.
