Old 09-01-2013, 11:35 AM
drew86 drew86 is offline
Mein Auto: 323i
E90 Battery question
Hello I was wondering if anyone here can help me I'm planning on parking my car for the season, should i be disconnecting the battery so it doesn't die, while it is parked.
Old 09-01-2013, 11:47 AM
floydarogers's Avatar
Pedant and Curmudgeon
Yes. Or buy a battery tender (trickle charger.)
Old 09-01-2013, 12:00 PM
3SJetblack's Avatar
3SJetblack 3SJetblack is offline
Mein Auto: 2013 E92 M3 ZCP
If you're parked in the garage, use one of these.
http://www.amazon.com/Multi-12-Volt-...ery+maintainer
Old 09-01-2013, 01:19 PM
ctuna ctuna is online now
Mein Auto: 325xi wagon
You might also consider
Putting the car on blocks so a flat spot doesn't develop on the tires and or
fuel stabilizer.
Even if you disconnect the battery it should be on a tender if you want max life out or it.
Old 09-02-2013, 07:05 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK
The BMW battery tender works very well. N4S
Old 09-02-2013, 03:28 PM
Mein Auto: '06 AW 330xi
Remember when you disconnect the battery, you have no way of opening the trunk after losing power. So you need to take measures to be able to get into the trunk when you want to reconnect the battery, like folding the rear seats down.
Old 09-02-2013, 07:44 PM
Gdiego Gdiego is offline
Mein Auto: 2011 BMW 328I xdrive
Battery question
I garage my 328 during the winter but take it out once a week when the weather permits. I hope this is sufficient for maintaining battery charge and other issues.
Seemed to work fine last winter.
