The X5 SAV Forum
Old 09-01-2013, 03:11 PM
jsatbimmerfest jsatbimmerfest is offline
Jubba
Mein Auto: 2003 X5 3.0L automatic
X5 outside temp reading
Hello every...
On my 2003 3.0L x5 i am having the issue where I am not able to get the outside temp. To read on my dashboard. When I press the BC button on the left side of the steering it will cot change. Is anyone having this issue?
Old 09-01-2013, 09:37 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Are you not getting just the TEMP to display (change)...or is the problem the entire OBC function (all 4) no longer can be called up?
If just the temp doesn't show up...check to see if you still have the temp sensor...or perhaps the wires are cut, or crud/dirt has corroded a connector. If the whole OBC function has stopped...it may be a problem with the button/turn stalk. Since this low cluster set-up & OBC has been around since the e36 3 series...I'm sure some BMW owner has had this issue and has discussed it or have a DIY. Again, this "low" or "base" instrument set-up can be found on e36/e46/e39/e53 BMW models imported to North America (US & Canada) and you may want to do a search on those forums...or even a google search.
Q {BMW CCA Member #191509}
(SOLD)
