Old 09-02-2013, 12:02 PM
Oooneil Oooneil is offline
Mein Auto: E65 745i 2003/12
E65 battery drain
Hello guys i have a problem with battery...***65279; I recharge battery and drive 2-3 days and car (battery) is dead.. If i dont move with car, i started it after 14 days without problem. I put new battery bosch and register it by diag, and problem continues. When im drive car, no problems no failure no errors. Where is the problem?
Old 09-03-2013, 10:21 AM
No advice? hmm
Old 09-03-2013, 10:43 AM
Nygel's Avatar
Nygel Nygel is offline
Mein Auto: BMW 750Li
The reason you have not gotten a reply, is because you have failed to read through the previous post on this topic. You need to read for direction because you have a battery drain. Something is not functioning correctly. You need the proper diagnostic tools or access to them to trouble shoot issue.
http://www.bimmerfest.com/forums/sho...d.php?t=434405
Old 09-03-2013, 11:12 AM
Diagnosis dont show any fault... Alternator is good battery is good... all units no fault... Its not normal problem i dont know where find... I have a car in 3 services...
Old 09-03-2013, 12:19 PM
Nygel's Avatar
you have a module or device that is not going to sleep possibly. Look at the ISM module above the battery also they acted up sometimes, these are just off the top of my head. What are you checking faults with?
Old 09-03-2013, 12:55 PM
In 2 services told me, all modules going sleep without problem, they trying disconnect all things, bluetooth etc. problematic things... My mechanic have inpa dis and thing on electric wiring. in second service have some machine to sleeping mode, and third service is original bmw, there i dont know what they using to diag...
It can be with some cable which controling charging battery? (Edit:It is this ISMmodule what about you talk?) because alternator giving good voltage and battery is new bosch and registered..
Can i try disconnect this module or i must take from other car?
Old 09-03-2013, 01:03 PM
Or how to check this module other way? Because diag dont show any fault....
Old 09-03-2013, 01:24 PM
Nygel's Avatar
This may sound crazy but how are the testing the alternator. For the alternator to charge the battery the car must be driven for no less than 30 minutes. Just letting it sit running does not charge the battery. With INPA or DIS it will only show codes, it cannot detect sleep (if I am not mistaken) you either have a device on the CAN bus that is faulty. as you mention they unplug Bluetooth etc, did they unplug or MOSTBus jumper out there is a difference.
After the car goes to sleep and you can still hear the CD changer cycling, there is you problem.
Old 09-03-2013, 06:40 PM
eibbed eibbed is offline
Mein Auto: bmw 760li
If your car has comfort access you should try the door handles. I had a vampire bleed on the battery a couple of times now and in each case I ended up replacing a door handle to make it go away.
Old 09-03-2013, 06:56 PM
SuperSnoop's Avatar
SuperSnoop SuperSnoop is offline
Mein Auto: 2007 760Li
E65 battery drain
How can you tell which door handle is bad? I heard they get warm if there is a problem, but I haven't been able to discern a difference.
Old 09-03-2013, 07:10 PM
TechFreak TechFreak is offline
Mein Auto: AC Schnitzer 745i Sport
Re: E65 battery drain
I'd guess that the Power Module didn't take the new battery registration and retained the previous battery values. Thats why you still have the same symptoms.
Re-register the Battery again.
Sent from my GT-I9100P using BimmerApp mobile app
My BMW ACS7
Old 09-04-2013, 04:27 AM
My dealer just disconnects an individual door handle and sees what difference it makes over night to the battery. Twice it's been the rear left that's been the problem although if you in the US that maybe the rear right. Just do them one at a time. My dealer did say that the handles were pretty unreliable and prone to shorts causing vampire bleeds. Fortunately mine all work correctly at this point in time.
Old 09-04-2013, 07:34 AM
Guys i dont have a comfort access, there cant be problem...
TechFreak: This problem starts when i have old battery, i think is old battery is bad and replace it and register in service and problem continues.
Old 09-04-2013, 08:59 AM
Nygel's Avatar
Like "TechFreak" said there could be a possibility the car did not accept the battery registration.
Old 09-06-2013, 11:54 AM
Today i was in car electric service, battery is OK alternator is OK all good.. I drive to my friend, after 1,5 hour i wanna drive home and battery is totally dead!! (in service was battery fully charged)
Old 09-06-2013, 11:56 AM
On thuesday i go in bmw service and they replace battery and reregister it...
Old 09-11-2013, 12:18 PM
ISM module replaced, battery dead again
Today new battery and registration.... Now im waiting when the battery die
Old 09-20-2013, 03:56 PM
Guys problem solved... All caused by 2 bad bosch batteries....
Old 11-02-2013, 10:20 PM
Greek champ Greek champ is offline
Mein Auto: 745 e66
I have the same problem But have found the fans on the gps etc in the boot just keep running !
One day the car is ok for a week , next it will be flat after my wife returns from shopping to the car !
Old 08-22-2016, 06:14 PM
Brasse25 Brasse25 is offline
Mein Auto: BMW 735
Same problem
New battery and registred, works for 1 week and now IT gets empty again, how DID people solve the drain issue, I can see that many have had this problems, So please you WHO have solved IT, tell me how
Old 08-22-2016, 09:58 PM
Rick in Yuma's Avatar
Rick in Yuma Rick in Yuma is offline
bimmerfest Supporting Member
Mein Auto: 05' 760li,94' H1,08'Smart
No simple answer. Provided above topics were double checked. Could be a lot of different circuits open. Here are some things to check.
http://www.justanswer.com/bmw/400cv-...004-745li.html
batter drain, e65 7 series
