The X5 SAV Forum
Old 09-03-2013, 03:25 AM
voidale voidale is offline
Mein Auto: x5
Unhappy Key Doesn't Work, Can't Start Engine, Can't Use Remote Control After Battery Removal
Hello guys,
My dad's 2005 X5 was low on battery, I tried to start up the engine (few times) it failed and reduced the battery even more. So I took it out and charged it over night at home.
Returning the battery back the remote key buttons unlock, lock, or backdoor open don't work. But what worse is when I put the key into the ignition hole I can only turn it 1 step. (Can't cycle it to try to startup the engine) and there is no dash lights or radio turned on.
Any ideas? The car doesn't recognize the key? Or it's something else?
p.s there is non standrat added alarm system in the car as well if this makes any difference (Gps tracking, Voltage monitor etc..)
Thank you!
Old 09-03-2013, 01:58 PM
X5DARKNESS X5DARKNESS is offline
Mein Auto: x5
Re: Key Doesn't Work, Can't Start Engine, Can't Use Remote Control After Battery Remo
This will solve the proalem for you
BMW 2006 X5 4.8IS / 79miles.
you must own BMW, because you will
Become More Wonderful
