Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 09-03-2013, 06:09 AM
thexpbogger thexpbogger is offline
Mein Auto: e28 1987 535i M Spec
Hot Under the Collar
G'day FOLKS,
it's been a long time since I put out a MAYDAY for help with my car yet again I am asking..
Just recently solved the bad case of the runs with the car P1551NG out the coolant after just driving for no more than 10 minutes.. (this is on a good day)..... After a messy check of ALL hoses and fittings coming up ok and the radiator and bottle fine the last checked cap turned out to be the BASTARD that was the problem..... OK.... now My QUESTION IS.... i need to replace the coolant temperature switch as a next step and sourcing them from auto parts suppliers around here, they ALL could only supply the twin connector switch and not the single one that is on my engine..... can the twin be used and if so any mods needed as in extra wiring or what??????
I am throwing myself at your mercy for help and advice...... finally get the car to a point of happy driving and do not like the dead temperature switch showing cold all day long....
PS.... the temp switch worked when i first got the car for a few days, then died and then almost 2 years later it awoke from slumber for half a day and is dead again....
Thanks for your help where given
Stephen
Old 09-03-2013, 08:54 AM
catso's Avatar
catso catso is offline
catso
Originally Posted by thexpbogger View Post
G'day FOLKS,
Stephen
I will look into it.
![/I][/FONT]
Old 09-03-2013, 03:41 PM
catso's Avatar
catso
I checked on your sending unit (part #62161360870) and the one that came up in my search has two wires. Look it up yourself on RealOem.com and maybe you will come up with a different number. If the number is correct, try the two terminal sending unit and connect to only one side and see what happens. Maybe the other terminal is for an idiot light?
![/I][/FONT]
Old 09-03-2013, 08:16 PM
Thanks for the quick reply CATSO...... unfortunately I do have that stupid light up above the rear view mirror and it is always on even after pressing the CHECK button......
PS.... during my thinking period (sleep) I had the thought that maybe the previous owner may have botched the job by fitting a single and joining the wires to fit...... maybe but I doubt that.... somewhat..... again thanks for the reply...
Stephen
Old 09-03-2013, 08:42 PM
catso's Avatar
catso
Stephen
Look at the drawing at RealOem.com (http://www.realoem.com/bmw/showparts...09&hg=11&fg=35 ) It shows the two-pronged temp sender, but on my 1988 528e, the similar reference shows a one pole sender. They both have the same threads, so they will fit in the same hole. Maybe the previous owner substituted a sender from a 528e into your 535i.
![/I][/FONT]
Old 09-04-2013, 03:32 AM
Now that is quite strange if that is the obvious word to use as per the so called BIBLE on these cars the BENTLEY PUBLISHERS BMW 5 SERIES SERVICE MANUAL blah blah blah etc etc section 10----cooling system----- page 5 top left image shows 2 connector as a 528e and below that image shows a single connector 533i & 535i..... the problem here is that the engine in my car is not the standard 3.5litre 6..... section 7-----fuel injection---- page 4 --- mine is the bottom injection system and it too shows the single connector.....although the picture is showing the wrong item as the sender... mine is connected to the thingy at the right next to the hose clamp on the upper radiator hose... pic attached
Stephen
Old 09-04-2013, 08:35 AM
catso's Avatar
catso
Stephen
The Bentley manual generally covers models sold in the USA, so yours may be different.
![/I][/FONT]
Old 09-04-2013, 07:58 PM
Thanks CATSO,
So that means my car is purely EUROPEAN SPEC..........
**** that hurts....... sourcing this part might be a little harder now..... next stop... EBAY...
thanks again for the help
Stephen
Old 09-04-2013, 07:59 PM
Thanks CATSO,
5H1T that hurts....... sourcing this part might be a little harder now..... next stop... EBAY...
Stephen
Old 09-08-2013, 10:39 PM
BMWFatherFigure's Avatar
Old School
Check with your stealer. They can get Euro parts (OK at a price). Does the plug seem factory? Has a new plug been soldered or bodged into position. Hi from Perth WA.
Current:
E38 Parts Car
Previous:
Old 09-12-2013, 01:06 AM
Thanks for your reply.... To me it seems legit and not a botch insert..... when i first got the car the temp guage actually worked whereas the radio antenna and hazzard lights did not.... with the radio fuse not connected and refitted and replacing the blown hazzard fuse, they all came back to life and the temp guage stopped apart from the one day almost 2 years later it worked for a few hours and again ceased to work......
Stephen
Old 09-12-2013, 08:00 PM
catso's Avatar
catso
Stephen
The www.RealOEM.com website is still probably the best way to determine the part number. Then you can search the various parts suppliers and dealers for the sending unit.
![/I][/FONT]
HTML code is Off
