Old 09-03-2013, 06:34 PM
fazlicdervis fazlicdervis is offline
Mein Auto: bmw
No map CD in the navigation computer. Please insert map CD.
I bought the latest navigation CD that came out. When I put in the CD it still says the same thing: "No map CD in the navigation computer. Please insert map CD." I checked the fuses, and the problem isn't with the fuses. What else can I check? Thanks.
Old 09-03-2013, 06:48 PM
BMW745ISliver BMW745ISliver is offline
Mein Auto: 2003 745I
My man i just fixed the same issue you have..This is what you should do. Call the local dealership and ask what part number your navigation system is ( in the trunk) and ask what numbers can match in the car cause you need to replace it. Then go on ebay and search for it and see if the parts are compatible..after that its plug and go.
Old 09-04-2013, 11:28 AM
bmoneyg bmoneyg is offline
Mein Auto: 2007 750 LI
What year is your vehicle and where is your NAV system located? I believe it is a DVD and not cd
On A good day
Old 09-04-2013, 01:04 PM
2003 745i and yeah DVD in the left side of the trunk when you open it up
Old 09-04-2013, 01:32 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
Re: No map CD in the navigation computer. Please insert map CD.
Looks like you need a new Navi unit
Old 09-04-2013, 01:49 PM
Thats what im saying
Old 09-04-2013, 03:06 PM
kjruben kjruben is offline
Mein Auto: BMW 760Li V12
It could just be the laser. I've read on the board that this is caused by the laser going out and once replaced it was fixed. I've seen a service on Ebay for this, but can't say that they are good as I haven't tried them.
Old 09-05-2013, 07:52 PM
Joe750's Avatar
Joe750 Joe750 is offline
Mein Auto: 750li
I had the same exact problem ! Then the Dealer replaced the whole unit ..
It worked fine .. But today it did it again
So tomm morning I'm taking my car back to the dealer ..
Old 06-06-2016, 12:08 PM
leeroy1998 leeroy1998 is offline
UTI Dude
Mein Auto: E39
Revive old post. Same issue with no read, but I already bought and replaced a new black cap laser lens for the unit for 29.99 on ebay, great deal. At first the disc wouldn't go in, figured I missed something when putting it back together. Yeah, the part that closes down on the disc, I forgot to put the tab in the slot, kind of tricky to get it to fit while closing it. But none the less it accepts disc...but now it don't sound like the docs goes in and spins......it use to before the change of the lens.. any advise?? I used grounding strap and was handling with care, and everything was smooth on the change. Do you think the drive motor for spinning the disc went bad just at that precise time of changing the lens?? Idk,...please help if any of you experienced this.
