E34 (1989 - 1995)
Old 09-03-2013, 10:08 PM
1995bimmerguy 1995bimmerguy is offline
Mein Auto: 540
540i heater core bypass
I suspect this has been covered before but i need to bypass the leaky heater core on my 1995 bmw 540i , and just in case it makes any difference this is the model with 6 spd manual transmission. Any solutions would be greatly appreciated .
Old 09-04-2013, 04:19 AM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
Under your hood three pipes should come out of the firewall. Connect the two that go to the heater valves together.
Old 10-22-2013, 04:00 PM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
This work? Im told i need to connect all 3
Bone stock 95' 540i/6 Blk/blk w/ ram style C.A.I / JBR LWFW/ DUDMD tune/ straight pipe /545 SSK /3.15 LSD / Rev-shift motor mounts/stage 4, 6 puck clutch/ K Sport coil overs/Eibach sway bars/ VAC under drive pulleys/weight reduction /sparco 368, Recaro seats, sparco harnesses, NX wet kit, M/T E/T streets.
"Skill can only get you so far, then comes money!"
R . I . P Paul Walker - 1973 - 2013
Old 10-27-2013, 08:50 PM
Resident e34 Racer
Connecting all 3 going into the firewall is the way for future reference.. They are 2 inlets running to 1 outlet..
