2007 335I tranny weird behavior - Bimmerfest - BMW Forums
Old 09-04-2013, 11:10 AM
riowongkp riowongkp is offline
Mein Auto: 2007 e90 335i jb4
Hi everyone,
My car is driving me nuts, I'm getting really tired to my my car. I tried everything to fix this problem, new hpfp, new plugs, new engine oil, intake valve cleaned. but it still exists. I'm here to try to get some helps.
I have a 2007 FBO jb4 no Meth e90 335i 78k miles. The problem is, every time I accelerate slowly from a light, the car hesitates in 1st,2nd and 3rd gear at low rpm . No matter It's cold or warm. I can hear my DCI sucks air roughly . It's very noticeable. And the funny thing is that it only does that when the jb4 is on. What the fxxk? It wasn't like this! However it doesn't hesitate if I give harder throttle. But i dont wanna always do that cus its killing my mpg. I have this problem since 76k miles. No code no power lost. I'm planning to do the last thing see if it works, transmission flush.
Do you guys had this happened before ? Any suggestion will be appreciated!
Sent from my SAMSUNG-SGH-I337 using BimmerApp mobile app
Old 09-04-2013, 11:35 AM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
Hesitation between gears or in gear at low rpm?
Old 09-04-2013, 11:48 AM
Re: 2007 335I tranny weird behavior
Low gears at low rpm.
Old 09-04-2013, 11:54 AM
Any idea? Accelerate slowly at low rpm in any gear.
Old 09-04-2013, 06:08 PM
fun2drive's Avatar
BMWCCA 149159
I would reset your transmission adaptations first and foremost and see how the transmission behaves. Personally I don't think the transmission has anything to do with it and it sounds like a JB4 issue. Have you discussed this with Terry?
Also check over at Bimmerboost since JB4, Cobb, Vishu have large threads on virtually every type of tune for the N54-55...
Old 09-04-2013, 07:07 PM
Thanks for you reply. I Did reset the adaptation. Unfortunately it still does the same. I've talked to Jon@BMS and he asked me to send him a log. And update my jb4 firmware. The thing is I don't have the USB cable to to those stuffs. I'm thinking is a transmission flush worth a shot... I've never done that and I have jerky shifting in DS mode .
Old 09-04-2013, 08:08 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by riowongkp View Post
Hi everyone,
Since 76k mi you say.
Last walnut shell blast was....when?
Old 09-04-2013, 08:21 PM
Also 76k lol , I think it started hesitate a week after the intake valve cleaned.
Old 09-05-2013, 05:31 AM
Time to read-em codes....here's interesting reading....
Old 09-05-2013, 06:28 AM
It seems like your issue has nothing to do with the transmission. You confirmed the issue happens when you are already in gear. Seems to me getting a USB cable should be less troublesome than flushing the transmission with almost 0 chance of improvement.
Old 09-05-2013, 06:35 AM
TheyCallMeNun's Avatar
TheyCallMeNun TheyCallMeNun is offline
Fest Wrks
Mein Auto: 07 335i coupe
After the the hesitation does it slowly and gradually take off or does it return to a normal pace?
I assume your car hasn't thrown a code yet? Which is kind of odd.. Especially if you're having such problems.
Have you tried removing JB to see if it runs properly under normal conditions?
Do easy and cheap trouble shooting first! Could save yourself some time, energy and money
BMW Owner Since 17
'00 323i
'07 335i coupe
Black Sapphire 6MT
BMS JB+ & DCI
Turbosmart BOV
Old 09-05-2013, 08:29 AM
Yea I see your point. I'm getting a transmission flush, let's see how it goes. Cus I always drive hard. I used to do WOT everyday on map2 with 91 gas. That's probably why my tranny got hurt? lol
Old 09-05-2013, 08:36 AM
It hesitates under a mild acceleration (inbetween 1000-3000rpm). If I give a little more throttle then the car just pull. There is no power problem since it pulls strong. I bet It's my tranny...
Old 09-05-2013, 08:38 AM
If I drive with map0 which is kind of stock setting, there is no hesitation...
Old 09-15-2013, 01:35 PM
85 roc it 85 roc it is offline
Mein Auto: 2007 335I
Mine is doing the same thing, but all stock. Dropped it off at dealer, will let you know the cause.
Old 09-15-2013, 03:00 PM
Let me know. Thanks!
Old 09-15-2013, 03:02 PM
tsantsa tsantsa is offline
Mein Auto: '06 330i
I think I may be experiencing something similar in my 06. I was used to driving the wife's 05 325xi and was really hooked on its throttle response and the way it went through the gears. When I got my 06 (something I didn't notice while test driving it...) I notice that there is almost a lag or something in the first couple of gears. On top of that, it's throttle response is different that the 05. I kept meaning to start looking into it but hadn't yet done it.
This problem seems a bit like what I'm feeling in my car. It doesn't exactly feel like something is wrong, but it just doesn't seem right either.
Old 09-15-2013, 03:49 PM
No code no warning light right? That's the thing driving us crazy. Recently I got a knock sensor code and I replaced the sensor. since a bad knock sensor can cause hesitation. After that my is a bit smoother but not perfectly smooth. Basically I can say the problem is still there, just got better...
Old 09-15-2013, 04:34 PM
No....not necessarily....read 'em with a capable reader, or risk missing it!
Old 09-16-2013, 01:15 PM
Well, ended up being the heating element in the charge tube. Of course. Not covered under certified warranty. Now trying warranty that I bought extra. Lets hope.
Old 09-16-2013, 01:25 PM
I don't get it can u please explain??
Old 09-16-2013, 02:09 PM
The car is losing boost through the charge tube from the turbo. It is going out the heating element ( what ever that is for).
Old 09-16-2013, 02:11 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
Heating element meaning intercooler maybe?
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 09-16-2013, 02:15 PM
So What you need to replace?
Did your car hesitate when you floored it?? Or same as mine only when accelerating slightly?
Old 09-16-2013, 02:16 PM
I had to look it up. But the piping from. The turbo to the intake has an attachment called the heating element. What it is fr once again I did not know. Mine is leaking boost at that junction. Think it would be best to by a BOV kit, I think that would replace the part. Plus not $1800
