The X5 SAV Forum
Old 09-04-2013, 04:08 PM
spudboy6 spudboy6 is offline
Mein Auto: x5 4.4
airbag fault 81
hello guys here with my first issue with my 2004 x5 4.4V8 lovely car just need to iron out the niggles
have had it on a snap on modus diagnogstic machine today for the air bag and it came back with
81- sensor for airbag front left
could anyone confirm with me that this is the sensor under the front passenger seat and is there any options out there of any sensors other than bmw ,
i know you can by-pass them but i would like to just have it sorted
thanks
scott
Old 09-05-2013, 06:44 AM
bmwoem1 bmwoem1 is offline
Past Sponsor
Mein Auto: X3
airbag fault 81
That fault is for the front left door airbag. When you remove the door panel, you will see it. The connector usually gets damaged or improperly reinstalled after removal
Old 09-05-2013, 12:06 PM
Mein Auto: x5 4.4
Airbag
Oh really good job I didn't go taking the seat out
Okay so ill have to have the door panel off then and inspect the connection , if the connection is fine what part would I be needing to replace ?
Thanks for the help
Old 09-06-2013, 01:51 PM
Mein Auto: x5 4.4
Removed the airbag this afternoon and inspected the connector and all is perfect in there looks like the panel had never been of before .
So the code says - 81 - sensor for left side airbag
Can someone tell me where the sensor is located for the side airbag and a link to one so I know what I'm looking for
Am I right it thinking its the one bolted the the chassis under the carpet facing direction of travel also known as a crash sensor ?
