Old 09-04-2013, 05:00 PM
Levine Levine is offline
Mein Auto: 328xi
Sorry... Headlight question
Does 2007 335i sedan left headlight would fit on my 2007 328xi sedan ??? (Both are xenons)
Mine is broken and I've found a used OEM for 137$ with exactly the same condition than mine.
Old 09-04-2013, 09:08 PM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
It appears they use the same headlight, according to Real OEM.
For 335i: http://www.realoem.com/bmw/showparts...07&hg=63&fg=05
For 328Xi: http://www.realoem.com/bmw/showparts...07&hg=63&fg=05
Incidentally, this is for US models. I believe Canadian headlights are the same, but you may wish to verify. Take the last 7 digits of your car's VIN and plug it into the Real OEM site.
Alpinweiß
E46, E83, E90 (all with three pedals)
F25
BMW CCA member
Old 09-05-2013, 09:38 AM
Mein Auto: 328xi
Thanks for reply !
I'll check that.
Old 09-05-2013, 02:14 PM
Mein Auto: 328xi
That's for CAN cars too.
Old 09-06-2013, 07:10 AM
Mein Auto: '06 AW 330xi
Yea but I'm not sure about the US, but in Europe, there are 2 versions of xenon housings, adaptive and normal non-adaptive.
But it will be a direct swap granted they are the same exact setup. Otherwise, you may need to re-wire.
Old 09-06-2013, 08:41 AM
Mein Auto: 328xi
When I start my car in the darkness, my xenon's bulbs go down for about a second and then replace. Is that means they are adaptative because of this up and down movement ?
Old 09-06-2013, 12:08 PM
Adaptive lighting is when the lights turn with steering wheel input. The self test on start (up and down movement) is a self test of the self leveling projector system. This is mandatory on all factory equipped xenon setups. The car does not do a visible self test for adaptive lighting like other manufacturers do.
Old 09-06-2013, 12:40 PM
Mein Auto: 328xi
So they're not. Thanks
