E34 (1989 - 1995)
Old 09-04-2013, 08:07 PM
makeshift525i makeshift525i is offline
Mein Auto: 525i
Car dies right after start-up/ engine died while driving
these problems suggested a fuel filter/injector issue, so I bought a new fuel filter and after replacing the old one, I now have a lower than normal idle speed (650-750 rpm) and the engine sort of chugs (for lack of a better word) here and there while in gear.
I am POSITIVE I installed the new filter the right way. Other than that, I'm not sure what else could it be. Any suggestions?
Old 09-04-2013, 10:34 PM
denny m denny m is offline
denny m
Send a message via AIM to denny m
Mein Auto: 1994 530i
Re: Car dies right after start-up/ engine died while driving
You might have a clogged fuel line. How bad were the filters you replaced?
Old 09-05-2013, 11:01 AM
Mein Auto: 525i
I can't tell how bad the fuel filter was, gas was able to leak out both sides of it though. how would I remedy a clogged fuel line?
Old 09-05-2013, 11:16 AM
denny m
Disconnect both ends and blow it out with an air compressor.
When was the last time you changed the plugs and coil packs.
Old 09-05-2013, 11:20 AM
denny m
Could be your fuel pump. Might check that first.
Old 09-05-2013, 12:45 PM
Mein Auto: 525i
Okay, so I might be an idiot, but I did some looking around online and came to the conclusion that I might have had the filter in backwards (I originally had the arrow pointing away from the gas cap) So I turned the filter around. probably a mistake, but I tried starting the car and nothing. tried again and there was a dead battery sounding clicking. tried again and it clicked for a second, tried to turnover, but didn't. I got a jump and was finally able to start it. Still ran just like it had before with the low idle speed and engine loping.
What is going on!? Is the filter on backwards now or was it backwards before?
The confusion came when removing the old filter: I took the entire bracket off and it fell to the ground. and found that the "in" and "out" ends are opposite from the new one. ( One end is rounded, one is pressed in on both filters, but labeled differently. )
Old 09-05-2013, 12:51 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
arrow points in direction of fuel.
Dont go confusing yourself with rounded and pressed ends and all that jazz.
As far as your $hit idle, check for vacuum leaks.
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 09-05-2013, 01:13 PM
Mein Auto: 525i
I get that the arrow points in direction of fuel, but since the filter is mounted left to right, not back to front, I can't tell which hose comes from the fuel tank and which one leads to the front of the car. Also, my fuel tank runs almost the entire width of the car, and both hoses look like they might be leading into it..
Should the arrow be point towards the passenger side or driver side?
Old 09-05-2013, 01:18 PM
Monsignor's Avatar
Mein Auto: Sig
the extra line is fuel return. The line the filter is on is NOT the return line, obiously.
while it should be a bit more obvious which way fuel direction is ( ) i believe it points to the driver side. Fuel filter is on the passenger side of the tank.
You also havent told us year or model - Help us help you.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 09-05-2013, 01:27 PM
Mein Auto: 525i
the extra line is fuel return. The line th efilter is on is NOT the return line, obiously.
Alright, that's the way I had it before The initial change in performance had me second guess the direction, then after it didn't start after 4 or 5 tries and still ran poorly, had me question it again. I apologize, I'm still a rookie to the Beamer DIY's.
It's a 1990 525i.
Old 09-05-2013, 01:34 PM
Monsignor's Avatar
Mein Auto: Sig
no worries. its why we're here lol.
Let us know how fixing it helps...
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 09-05-2013, 01:40 PM
denny m
Here's a picture of mine. Just changed it 2 weeks ago.
Old 09-05-2013, 01:41 PM
denny m
Top of the picture is the passenger side. If that helps you.
Old 09-05-2013, 01:42 PM
Monsignor's Avatar
Mein Auto: Sig
not to confuse the ever living fcuk out of OP but your car is different and thus has a different filter.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 09-05-2013, 01:59 PM
denny m
Haha, I didn't see the post he did with the make and model.
It's clearly a gas issue though. Too just die in flight like that..
Old 09-05-2013, 02:06 PM
Monsignor's Avatar
Mein Auto: Sig
not at all. Could very easily be a severe vacuum leak.
To be a fuel issue, it would have to be a dead pump, or blown relay. both of which would pretty much just stop and wouldnt be able to fire back over.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 09-05-2013, 02:13 PM
Mein Auto: 525i
So I swapped the filter so that it's facing the correct direction again, and the battery is dead again. Once I get it jumped I'll check for any vacuum leaks and let you guys know. At this point I'm beginning to doubt whether or not the fuel filter was the culprit in the first place.
Thanks for the advice though!
Old 09-05-2013, 02:14 PM
denny m
Holy, I learned something new.
Old 09-06-2013, 06:50 AM
Monsignor's Avatar
Mein Auto: Sig
let us know how it goes
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 09-08-2013, 07:12 AM
Mein Auto: 525i
Got the car running finally. Turned out the battery was bad (I suppose it was just a coincidence that it stopped holding a charge while I was working on the car.) and for the roughness, that "chugging" I described earlier, was smoothed out by adjusting a long nut on the throttle body linkage ( I had taken the throttle body off about month ago, So I assume I may have unknowingly adjusted it when messing with the linkage cables?)
I'd like to believe the fuel filter helped as well, the car no longer (as of yet) starts then immediately dies.
Thanks again for the suggestions, I'd be lost without the great people on BF!
fuel filter, low idle, replacement
