Old 09-04-2013, 11:27 PM
Bigrob126's Avatar
Bigrob126 Bigrob126 is offline
Mein Auto: 2010 328i Coupe Auto
I'm assuming no oil cooler?
Just want an ez yes or no answer about whether my 328 has an oil cooler or not, although I think I already know this answer! Seeing an oil TEMP gauge, as I had in my 370Z, I figure means " You AINT got an oil cooler, so keep a good eye on how hot your oil is getting!" Not that I need one in a 328i, but I would like to feel better protected if I get a little pedal happy in the summer heat!
Rob
Old 09-04-2013, 11:36 PM
AnJing408 AnJing408 is offline
Mein Auto: 2007 335i
I doubt it since it doesn't even have turbos.
2007 335i coupe/M-aero front lip spoiler/M3 trunk lip spoiler.....SOLD
Old 09-05-2013, 02:45 AM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
No oil cooler on the 328.
Actually, I was surprised at your saying you have an oil temp gauge in a 328. Back when I was looking at both, the 335 had oil temp and the 328 had a mpg gauge in its place.
Old 09-05-2013, 03:27 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
This should help you identify whether you have a cooler - though as has been said, unlikely with a NA engine...though you might have one of the water/oil heat exchangers.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof
Old 09-05-2013, 06:36 AM
grijo grijo is offline
Mein Auto: 2013 BMW 328i Coupe
Newer 328 has an oil temp gauge in lower part of the tachometer.
2013 BMW 328i
2008 Honda S2000
1972 MB 250C
Old 09-05-2013, 06:40 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK/335d
I have an oil cooler and an oil temp gage, so it is not mutually exclusive. N4S
Old 09-05-2013, 07:25 AM
Originally Posted by need4speed View Post
I have an oil cooler and an oil temop gage, so it is not mutually exclusive. N4S
I've owned my 13 328i sport and M packages for two weeks. I am not that familiar with the engine and other mechanical components. Maybe I have one also, but I do not know.
2013 BMW 328i
2008 Honda S2000
1972 MB 250C
Old 09-05-2013, 08:39 AM
floydarogers's Avatar
Pedant and Curmudgeon
+This. Although I would have just said "NO".
COUPES have an oil temp gauge, though I'm not sure if it's restricted to certain years.
Old 09-05-2013, 09:00 AM
Bigrob126's Avatar
Do our cars go into limp mode if too high an oil temp is reached?
Rob
Old 09-05-2013, 09:30 AM
bwillia's Avatar
bwillia bwillia is offline
Just another Gear Head!
Mein Auto: 2008 335xi coupe
It was my understanding that sport package gets an oil cooler but without that option then no oil cooler. But either way if you have one it is very very easy to see inside the front of the RF wheel well.
Old 09-05-2013, 09:48 AM
Phil325i's Avatar
Or you could have a heat exchanger which bolts on to the oil filter housing (item 9 in the diagram):
Name:	Heat Exchanger.png
Old 09-05-2013, 10:08 AM
++ Beat me to it.
Old 09-05-2013, 10:21 AM
Zooks527's Avatar
If it got there, it would.
However, as I have NEVER seen a report of an oil overtemp on a 328 (excluding water pump / thermostat failures), I don't expect to see one in the future. Hell, I have a 335 without an oil cooler, and I've never come close to an oil temperature limp mode, even on 105+ degree days. People living in the hotter states run them in high temps all the time without issues.
Old 09-06-2013, 09:32 AM
SoCal3 SoCal3 is offline
Mein Auto: E92 328i
Based on the earlier post, my 2012 328i M pack doesn't have the oil t stat as shown in the images, but it does have this. Either on oil cooler or trans cooler or PS cooler. I've not followed the lines back to their origin yet.
Old 09-06-2013, 10:02 AM
Phil325i's Avatar
That's the water/oil heat exchanger shown in post #11, but mounted in a different place in the engine bay. So could be for the PS fluid rather than the engine oil. You'll have to trace the pipes...
