Old 09-05-2013, 05:47 PM
mucci1973 mucci1973 is offline
Mein Auto: 2002 745li
Exclamation Help! no power! wont take my key! towed home
Well, I'm praying someone can help give me some guidance. 2002 745 li. 2 months ago ( July 4th!) I had my alarm go off, found the car dead, eventually got it jumped then to the dealer. got a new battery. Then towed it from the dealer to a local mechanic who installed a re-built alternator and the car worked fine. NOT SURE IF IT MATTERS THAT THE CODING OR REGISTERING HAPPENED PRIOR TO MY NEW ALTERNATOR. Yesterday I was with a friend and got a little crazy, picked it up a couple times, did some bobbing and weaving in some traffic and braked fairly hard but not enough to skid my tires or anything. Pulled over to drop friend off and as I was idle I got DYNAMIC DRIVE FAILURE, TRANSMISSION FAIL SAFE, AND REDUCED POWER ENGINE MALFUNCTION, AND SOMETHING ABOUT BRAKING SYSTEMS. I was able to get the car home by turning it off then on again and putting it into drive again quickly. The car drove with no dash lights, no radio, no nav, also wouldn't switch gears (1st gear all the way home) got home, turned off car then re-started and no codes re-appeared, it seemed like everything was fine. Today, drove to work, gears shifted fine, no codes. ALL of Sudden car parked for 3 hours then Alarm went off. No Power, wont take key, so I disconnected 3 cables that lead from the battery to the fuse panel in the trunk hoping to disable alarm. the alarm eventually turned off. I reconnected the cables to the panel and still nothing. Tried a 3 minute jump from the tow guy and still no power! Flatbed Towed=( AAA advantage....HELP
Old 09-05-2013, 06:03 PM
Nygel's Avatar
Nygel Nygel is offline
Mein Auto: BMW 750Li
you still have a power issue take it back to the dealer. The only other thing could be your power module, or even the battery was not register correctly.
Check your power switch above the battery.
Old 09-05-2013, 06:25 PM
Busarider Busarider is offline
Mein Auto: 745LI
Replace ISM & register battery
Old 09-05-2013, 06:35 PM
the battery switch is on.
Old 09-05-2013, 07:02 PM
Nygel's Avatar
then look into the items above.
