Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 09-06-2013, 12:57 AM
thexpbogger thexpbogger is offline
Mein Auto: e28 1987 535i M Spec
May the COLUMN it FREE you
G'day FOLKS,
Me again with another query to an old reply I asked many many moons backs..... It seems that I am still having a BA5TARD of a time with the steering column being in the ALL OUT position making for a squeeze to get into and driving the car.... I have since stripped the covers from the column and found the once hidden lever...... pulling lever towards the wheel allows for marginal slop and pushed towards pedals locks it in place.... in the diagram of the exploded view of the column..... SUSPECT #1 is the culprit of the problem as I am being informed some time back..... now is this an opposite thread to release or normal, this MONGREL is tight as and any info as to how to loosen would be helpful.... use of CRC & WD40 still will not let it go????????
Stephen
Name:	e28 column nut.jpg
ID:	395391   Click image for larger version
Name:	e28 column.png
Old 09-06-2013, 03:38 AM
south26 south26 is offline
Mein Auto: 535i 1989
Sorry but the normal way is the only way use a big wrench.
Andy
Old 09-06-2013, 04:04 PM
catso's Avatar
catso catso is offline
catso
I've been using a product called "CRC Freeze-Off" lately with pretty good results; try some of that.
![/I][/FONT]
Old 09-06-2013, 11:49 PM
Appreciate the quick reply DUDES!!!!!! Unfortunately a bigger wrench or shifting spanner makes it that little bit more harder due to the awkward position it is to get at the MONGREL!!
As for the CRC freeze off spray, never heard of it but might go to auto shop to suss out
Thanks again with a smile
Stephen
Old 09-08-2013, 10:35 PM
BMWFatherFigure's Avatar
Old School
Best and cheapest is ATF and acetone (trust me). The 32mm nut is rh thread. Even if you only get a fraction of a turn at a time use the biggest weapon you can get in there. NOT Stiltsons - they will crush it. Try a secondhand tool shop maybe???
Current:
E38 Parts Car
Previous:
Old 09-12-2013, 01:17 AM
Again thanks for your reply,
Glad I caught this before attacking the column again as I just got my hands on a pipe wrench and was trying again....... PHEW!!!! lucky..... now not wanting to be a nuff nuff but what is meant by the ATF and acetone.... figured acetone being nail polish remover but what method is to used with these......
more info please...... i don't want to wreck the column in any way possible...
Stephen
Old 09-12-2013, 04:32 PM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
ATF and acetone mixture used as a penetrant.
http://www.bmwlt.com/forums/showthre...=acetone%2Fatf
Old 09-13-2013, 01:02 AM
Thanks for the link...... will be hitting the column with this mix and pray....
Thanks again
Stephen
HTML code is Off
