The X5 SAV Forum
Old 01-27-2017, 08:41 PM
westnwahs westnwahs is offline
Mein Auto: 2004 X5 3.0
04 X5 Lower heat vent- no output
My 2004 X5 3.0 air vent has no heat or air coming out when turned to the feet position on the three way dial. I have looked underneath for something obvious- nothing seemed stuck in opening. Not sure where to start...
Old 01-28-2017, 09:18 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Welcome! I've moved your question to our X5 forum.
Old 01-28-2017, 02:07 PM
QSilver7's Avatar
If you have the manual IHKR (with 3 dials) instead of the automatic IHKA system...then the air distribution dial (#2 in illustration below) is attached to 3 cables...which manually actuate the air flaps as the dial is rotated.
Have you pulled the IHKR to check the operation of the bowden cables?
Q {BMW CCA Member #191509}
(SOLD)
Old 01-28-2017, 02:49 PM
Danke Schon!
Wunderbar! Took about 3 minutes to reattach the green cable. Thank you.
Old 01-29-2017, 05:27 AM
QSilver7's Avatar
(SOLD)
lower heater vent
