Old 09-06-2013, 09:10 PM
Drastic08 Drastic08 is offline
Mein Auto: 95 BMW 740il
need rims and tires for a 95 740il
Hey guys i am new to this forum but i am wondering if the 2008 BMW 7 series wheels would fit my 95 740il
this is the one i want to put on
http://www.slickcar.com/products/aly...7n01101953.jpg
please help_a_
Old 09-11-2013, 01:15 PM
dctazz dctazz is offline
Mein Auto: 1995 BMW 740iL M38 M60
Post BMW Wheel Information You Need To Know
The wheel centre bore on the 1995 is 72.6mm, the offset is 23mm.
Things you need to know:
1) Offset
2) BMW OEM wheel information
NOTE: Wheel information is in German, and ET is the wheel offset.
3) Centre bore adapter
4) Wheel spacers
5) BMW Wheel Spec
6) More BMW Wheel Styles
7) Wheel & Tire Calculator
Keep in mind a 7 series is a very heavy car. OEM wheels are 16 and 17" any larger and you take the chance of bending the wheel if you hit a pothole.
I don't like to use any wheel spacers, it changes the load on the suspension.
eBay links are only for reference.
A quick way to tell what size is the centre bore of a used wheel when shopping.
Take and old credit card, cut the card at 74mm. Measure down to 72mm and cut out a notch. You now have a pocket gauge.
Old 09-11-2013, 02:12 PM
BMWFatherFigure's Avatar
Old School
Love the pocket gauge idea!! I learn a new trick every now and again - this is a gem!
Current:
E38 Parts Car
Previous:
Old 09-11-2013, 04:38 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
The 3 major wheel specs to consider when looking for BMW wheel compatibility are listed below
  1. wheel bolt pattern
  2. wheel offset range
  3. wheel center bore/hub size
After those 3 specs above, one must also consider TIRE size (some models use a different tire circumference/diameter), wheel width (too wide can get you in trouble), wheel bolt length if you're using wheel adpaters/spacers.
Now that BMW is offering AWD across the board on every model...it has changed the wheel compatibility somewhat. It used to be that the 5/6/7/8/Z8 models could share the same wheels (with the exception of the e39 with its larger 74.1mm hub)...and the 3/X/Z3/Z4 shared the same major 3 specs. But now, some of the AWD models have higher offset ranges than their RWD sedans/coupes cousins...and you have the e70/e71 X5M/X6 models which have a split axle wheel hub size.
Q {BMW CCA Member #191509}
(SOLD)
2008, 740 il, 95, wheels
HTML code is Off
