E34 (1989 - 1995)
Old 09-07-2013, 12:18 PM
tward182 tward182 is offline
Mein Auto: 1992 BMW 525i M50 E34
Need help!!!
My 92 525i has 214,000 miles. It is running pretty rough. Just change fuel filter and fuel pump.
I get off and on shaking pretty badly. Brother thinks its the timing.
Any ideas/help?!?!!?!
Old 09-07-2013, 12:39 PM
Tomo540i Tomo540i is offline
Mein Auto: 1995 540i 6 speed
Re: Need help!!!
It might be that not all cylinders are firing. Did you recently change the spark plugs?
Sent from my LG-E973 using BimmerApp mobile app
Old 09-07-2013, 01:08 PM
With in last year or so. One of my crankcase hoes was actually unplugged... not good haha! ordered both of those hoses. Hoping this works. Brother thinks its the timing but gonna put that at my last idea.
Should i try replacing all six coil packs as well?
Old 09-07-2013, 01:25 PM
Re: Need help!!!
I wouldn't do it just yet. Did you check to see if you have any error codes?
Old 09-07-2013, 01:30 PM
Give this a try.
http://www.bimmerfest.com/forums/sho....php?p=5936965
Old 09-07-2013, 01:48 PM
trying to upload the video of the stomp test but its not working
Old 09-07-2013, 02:04 PM
Re: Need help!!!
Are you getting a code?
Old 09-07-2013, 02:05 PM
here is link. I dont know how to read it
Old 09-07-2013, 02:19 PM
I believe it is:
1251 Fuel Injector 1 (or group 1 for DME 1.3, cylinders 1, 3, 5)
Look at the check engine light (flashes once pause, then twice pause, then 5 times then 1 time
Old 09-07-2013, 02:22 PM
okay great! I will order that and hopefully it helps! I found out that one of the crankcase hoses attached to intake boot was disconnected. Hoping that these few things will help. Thank you for your help!
Old 09-07-2013, 02:25 PM
No problem, I use it any time there is a problem with my car, good luck hope it helps!
Old 09-07-2013, 02:36 PM
Re: Need help!!!
Let me know how it goes!
Old 09-07-2013, 02:37 PM
will do. thanks again! Do you know if Fuel injector is easy to change?
Old 09-07-2013, 03:01 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
yes. but you probably have a coil pack problem. 214K is a long time for 6 coil packs to be firing regularly. i would look at those. My E90 had a sever misfire a couple months ago, 54K miles and 2 coil packs were shot....
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 09-07-2013, 04:22 PM
Re: Need help!!!
You said it haha
