Old 09-07-2013, 06:13 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
DIY Headlight restoration (Great results!)
Will post more details and a DIY later.. but here's the money shots!
Before:
After:
Old 09-07-2013, 07:00 PM
mpower997's Avatar
mpower997 mpower997 is offline
Mein Auto: '90 325i
Looks great, I look forward to the DIY as my lenses are super tired.
545i*Sport*6Speed*Cold Weather/Smokers Pkg*Cdv delete*Scoop/Exhaust*147k Miles
Old 09-07-2013, 07:09 PM
boost7 boost7 is offline
Mein Auto: 05 545
wow, what product did you use? amazing before and after
Old 09-07-2013, 10:47 PM
bimmerfan52 bimmerfan52 is offline
Mein Auto: 545i
Looks fantastic!
Anxious to hear your formula.
Old 09-08-2013, 02:04 AM
Mike Swing's Avatar
Mike Swing Mike Swing is offline
Mike Swing
Send a message via AIM to Mike Swing
Mein Auto: 2000 Z3M 2007 530i
Whoa!
Mike Swing
Old 09-08-2013, 06:03 AM
DIY'er
No commercial kit was used.. Just sand paper and paint
Originally Posted by bimmerfan52 View Post
Looks fantastic!
Thanks. It is pretty simple. Putting together a bunch of pictures for a DIY
Originally Posted by Mike Swing View Post
Whoa!
I'll take that as a compliment
Old 09-08-2013, 06:36 AM
skj69nyc skj69nyc is offline
Mein Auto: 535i X drive
Looks Great !!! Please list all material used. I need to keep this in my to do list.
Old 09-08-2013, 05:42 PM
DIY'er
Here we go..
First, you do not need one of those "kits". Go buy a pack of 200 grit, 600 grit and ~1000 grit sand paper. The last two should be wet/dry
Basically the idea is to sand off all the old clear coat and any scratches, and yellow plastic, then put a new coat of clear coat on them.
Start by taping up the car to protect it--keep an eye on the tape. I had to add more a few times as I was wearing through it
Here's sanding with 200 grit--see how nasty and yellow the dust is? That's why your headlight isn't clear!
Close up
Yes, they should look like this at this point. See how they're starting to turn white? That is good
Another angle
Close up--notice dust is turning white. That means you're through the yellow gunk
Some yellow and white dust
Close up--little scratches like this need to be gone before going to 600 grit. If you can really catch it with your fingernail, worse than the scratches the sand paper is leaving, then you haven't sanded enough most likely
Most of these are fine
Don't be scared!
Old 09-08-2013, 05:49 PM
DIY'er
Once all the major gunk is gone, switch to 600 grit. Get a squirt bottle, put some dish washing soap + water in it. Use it to keep the head light and sandpaper wet. Keep cleaning the white gunk off the sand paper every little bit
Should look something like this:
Ew
Getting a little more clear..
Other side
Keeep sanding
Here it is after 1000 grit + it's wet
Here is after 1000 grit but dry.. this is enough sanding
That's enough sanding! Ignore the guides that say go to 1500, 2000, 3000, buffer, etc. etc. You don't need to do all that.
Old 09-08-2013, 05:53 PM
DIY'er
Paint time! You need an automotive grade exterior clear coat (will have UV protection in it)
This is right before paint--mask off the back of the light, computers, etc. I hit this with 1200 grit one last time
Both
Here's what they really look like
About to be painted (actually this may be right after first coat, I can't tell in the picture)
One more, pretty sure this has paint on it (actually, the bottom section of plastic is still clear, so maybe it doesn't. Regardless, you get the idea)
Old 09-08-2013, 05:57 PM
DIY'er
This is right after clear coat was put on---looks really white, but will go clear once it starts to dry
Another angle
Starting to clear out a little
More
There we go
In the oven (you don't need this $100K oven, lol, but it will take a lot longer to dry without one)
In the oven, condensation is another issue and was there before this
Out of the oven--water is a little better
ta-da!
BAM
Old 09-08-2013, 06:01 PM
DIY'er
And finally, here they are!
Old 09-08-2013, 06:09 PM
DIY'er
And last bit of info--depending on how much dirt ends up in the clear coat, you may have to wet sand that with 2000 or 3000 grit until it's smooth, then buff out those spots. I had one spot that was pretty bad that I did that to today, but that was from a mess up. We took it them of the oven and somehow got one dirty before putting it back in, and the paint was still sticky enough for it to mess it up.
Overall, not that bad, and amazing results IMO
Old 09-08-2013, 06:40 PM
GREAT JOB, I VOTE STICKY with 4 gold stars
Old 09-08-2013, 06:45 PM
DIY'er
I vote for sticky as well
Old 09-09-2013, 10:48 PM
okii okii is offline
Mein Auto: 530i
Looks great. How is the clear coat applied? Brush, spray, foam brush?
Any particular brand of clear coat?
Old 09-10-2013, 07:17 AM
DIY'er
HVLP paint gun was used to paint them. The paint used was an exterior clear coat that BMW uses but it's from a German manufacturer so it's not a name most people could get. I'd recommend going to a local auto paint store and getting any decent exterior clear coat. Sherwin Williams and PPG are probably the most common. Maybe DuPont as well
Hope that helps.
Old 09-30-2013, 02:05 PM
lib lib is offline
Loving my car.
Mein Auto: 2007 530xi
Wow, amazing.. Awesome post!
I feel a bit silly now having lived since 2006 with white paint transfer that ended up on my headlight the scene day I had my car!
Edit: I misjudged the turning radius while parking.. The white paint was from the parking structure..
Garage:
  • 2014 X3
  • 2007 530xi
Old 09-30-2013, 02:09 PM
DIY'er
Thanks! That should be fixable for sure
Old 09-30-2013, 06:38 PM
dwlink's Avatar
dwlink dwlink is offline
Mein Auto: 435i Gran Coupe
Great post with awesome looking results. I did mine (again) a couple months ago using the Sylvania kit with much better results than the first time with a cheapo kit.
A small tip that might save you some time and some tape - Rather than taping off the hood above the headlight, you might consider just popping the hood and lifting it up a little bit.
2015 BMW 435i GC MSport (ED Sept 29, 2014)
2004 BMW 530i (retired)
Old 10-01-2013, 04:31 AM
DIY'er
Thanks, yeah I realized that little waste of time about halfway through, lol
Gotta do them on the ol backup car next, 2004 accord. It should make a huge difference on it as they're pretty rough
Old 10-01-2013, 07:50 PM
BickUW89's Avatar
BickUW89 BickUW89 is offline
Go Dawgs!
Mein Auto: E60 550i SP
Schpenxel , you've got a big 'ol pair of brass ones!! You've been taking on some big projects and getting great results. Consider me a fan.
My LCI 550i has ~75k miles on her, and I want/need her to last another 2.5 years or so. You seem to have the magic touch with these cars.
Great job, brother.
BMW Ergo Zoom
IMHO: E39 < E60 > F10
2016 F82 //M4 (ED July 6, 2016)
2011 F10 535xi (ED July 15, 2011)
2008 E60 550i (ED July 22, 2008) (Retired)
2000 E39 540i (Retired)
Member BMWCCA #402733
Old 10-01-2013, 07:53 PM
DIY'er
Originally Posted by BickUW89 View Post
Schoenberg, you've got a big 'ol pair of brass ones!! You've been taking on some big projects and getting great results. Consider me a fan.
Great job, brother.
Thanks! I hope to have helped some people on here at least save some money if nothing else.. underneath a little bit of tech, the basics are the same as most other cars
The magic touch seems to have run out tonight though, found a cracked cylinder. Have a used long block on the way out of a 745i, so it looks like there will be a "how to R&R an engine" thread in a few weeks
Old 10-01-2013, 08:56 PM
Mein Auto: 545i
Sorry to see that man.
Looks like you will have to endure the the DD a little longer.
Do you think the crack was the result of attempting to clean the secondary air injection system or was it just coincidence?
At least you were lucky that you discovered it close to home and not on a long trip. Depending upon the severity of the crack and where the piston happens to stop on that cylinder, the pressurized cooling system can actually fill the cylinder with coolant, with hydrolock being the nasty surprise on the next start up.
Good luck with it man. I know you will do a quality job and provide plenty of photos and documentation for the rest of us to savor!
Old 10-01-2013, 09:06 PM
javablack javablack is offline
Mein Auto: E 61,E 65, 10 range rover
looks great!!!
headlight, restoration
