Old 09-09-2013, 08:43 AM
BigDeep1's Avatar
BigDeep1 BigDeep1 is offline
Festaholic
Mein Auto: 2011 535i Sport
Suspension THUD/THUNK normal on an F10???
I hear a thud and thunk from my suspension when I go over large uneven surfaces. It almost feels (and sounds) like the heavy wheel and RFT just plops down when going over these surfaces. I assumed that was a normal sound with these heavy rolling-rock RFTs and heavy wheels on the F10.
Should I bring my vehicle in to the dealership to trouble shoot this? Is this noise not to be expected?
THIS thread on F10 post made me question it. I believe the dealership told him that they needed to replace his shock. It went away temporarily for him; however, came back after a while.
2011 535i Sport (Prem 1, 2)
Old 09-09-2013, 12:52 PM
tularockstar tularockstar is offline
Send a message via ICQ to tularockstar
Mein Auto: 2011 BMW 535i
It's definitely not normal. You should experience no thump and/or thud from the suspension.
Old 09-09-2013, 03:47 PM
markl53's Avatar
markl53 markl53 is offline
bimmerfest Supporting Member
Mein Auto: 2014 535i
You've had your car for a while, right? Has it made this sound all along? As far as "rolling rock RFT's", what pressures are you running? My 2011 535i is set at 34 front, 37 rear, or thereabouts. Sound like you might be over-inflated (not causing the "thud", just saying from your comments about the tires).
BMW-CCA
Bimmerfest Supporting Member
2014 535i Individual | Azurite Black/Amaro Brown Merino | Premium | Cold | PDC | Rear Camera | Anthracite Hdr
Prior: 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA | OEM Alarm
Prior: 2005 330i 6MT | Black Sapphire/Sand Leather | Premium | Cold | UGO | OEM Alarm
Old 09-09-2013, 04:50 PM
playdrum's Avatar
playdrum playdrum is offline
Enthusiast
Mein Auto: 2013 535xi M-Sport
Where do you hear it coming from, the rear of the car or from all 4 corners?
2017 540xi M-Sport | Bluestone/Black Dakota Leather/Rhombicle Trim |19" 664 Wheels | Premium | Cold | Driver Assistance | Driver Assistance Plus | Ceramic Controls | Multi-Contour Seats | HK Surround Sound | Apple Car Play
Prior: 2013 535xi
Prior: 2011 535xi
Prior: 2009 528xi
Prior: 2006 330xi
Old 09-09-2013, 07:13 PM
550newbie's Avatar
550newbie 550newbie is offline
Mein Auto: 2014 550i X-drive Msport
I just purchased my 2011 550i today and noticed the thump/thud on the way home. It seems to be coming from the rear. As BigDeep1 mentioned, it happened when going over uneven surfaces (about 70mph on a strip of highway that has a slight rise, then a fairly sudden fall and at about 50mph under the same circumstance).
Old 09-09-2013, 10:29 PM
HMtheJJ HMtheJJ is offline
Mein Auto: '13 M6, B7, LX570, CGT
F10 has one of the stiffest chassis, but it makes all sorts of noises, feels very refined and luxurious when driving on smooth paved road, as soon as it gets rough, oh man, not a nice car to be in, then again, maybe I'm just too used to the LS
Old 09-09-2013, 10:48 PM
ausdude's Avatar
ausdude ausdude is offline
Mein Auto: 2013 BMW 550i M-Sport
I've never heard anything like that. However, I have the passive suspension. What kind do you have?
Untitled[/url] 550i M Sport|300|LCSW|4MR|2TB|704|760|PDC|ZEC|6F2|ZDA|5AD |416|494|Dinan Stage 2|CF Spoiler,MirrorCaps&Splitter|M Performance Diffuser|Front Reflector Delete|Black Grilles|Rear Fog Lights|Euro Side Mirrors&Tail Lights|M5 Front & M550D Rear Sway Bars|20" HB04|Roof Wrapped|Coded|CCA member
Old 09-10-2013, 04:31 AM
grizzles's Avatar
grizzles grizzles is offline
550 XI M Sport F10
Mein Auto: 550 xi Msport
I recently have been getting a hard thump from the rear at certain times usually at higher speeds at a step in the road from construction or at slower speeds on a speed bump.
It doesn't matter what the setting is for the suspension. Comfort mode still will create the thump in the rear.
It feels like something is stuck in the suspension not allow it to bounce properly.
2011 550i Xdrive, Sophisto Grau, Anthracite/Black Dakota, Active/ventilated seats, Cold Weather, Convenience, M Sport, P2, SAT, HUD, top and side view cameras, power rear sunshade, split fold down seat, comfort access, SAT Radio, rear view camera, 35% window 3M tint, Dinan Stage 1 (soon)
Old 09-10-2013, 05:58 AM
Nison's Avatar
Nison Nison is offline
Mein Auto: 2011 535i xdrive
i got both of my front shocks replaced under warranty for the noise.
Old 09-10-2013, 09:31 AM
Ed'sBMW Ed'sBMW is offline
Mein Auto: 2011 535
I have a 2011 535 and have and do still experience this problem. Happens most often when the rear wheels are crossing over a speed bump, it doesn't happen every time. Sounds like the rear end just fell out of the car. I reported it during my first service appointment but they were unable to recreate the condition. So I just hold my breath each time I approach a speed bump. Pretty embarrasing when you have someone riding in your 70K car and it makes such a THUD!
Old 09-10-2013, 07:56 PM
bmguy bmguy is offline
Mein Auto: 2012 Dinan 550xi
I had an issue where some of the junk in the little kit mounted to the trunk lid came loose and was rolling inside the kit, I removed it, and haven't had an issue since. Have you guys looked at the kit to see if the parts inside came out of the holders they were fitted into?
Old 09-10-2013, 09:15 PM
PeterC4 PeterC4 is offline
Mein Auto: 535xi,328xiC
I have no thuds....go to dealership.
2012 535xi M-Sport, Carbon Black, Cinnamon-Alum Hex, Exec Pack, Tech Pack, HUD, Damper Control, BMW Apps, Heated Rear Seats, BMS Tune
Old 09-10-2013, 11:17 PM
BigDeep1's Avatar
Festaholic
I too would say that the noise comes from the rear. Describing it as the "suspension falling" when going over large uneven surfaces is a great description. I am also amazed at how choppy the car feels when accelerating when driving on a bad bumpy road. It feels like the rear skips and jumps. My old mustang did this, but it had a rear live axel.
My gut tells me that this is just inherent to the F10. I have an appointment with the dealership on Thursday. It will probably be a waste of my time.
Old 09-11-2013, 03:00 PM
550newbie's Avatar
Thanks BMGUY. The locking lug key was loose...hopefully that was it. The ride does still seem choppy, but the noise seems to be gone.
Old 09-11-2013, 10:26 PM
jmfan's Avatar
jmfan jmfan is offline
Mein Auto: 2014 Jaguar F-Type S
I am not experiencing any thud/thunk on my car at all. I just took a 68 mile trip tonight and it was remarkably smooth and quiet on all road conditions.
2014 Jaguar F-Type S Ebony/Jet
Previous:
2012 535i M Sport Alpine White/Oyster & Black
2011 328i Convertible Mineral White/Oyster & Black
2006 325i Convertible Alpine White/Tan
Old 09-12-2013, 09:54 AM
mrashton mrashton is offline
Mein Auto: F11 530d SE; F45 218i 2AT
I would ask for a technician to join you for a drive where you can demonstrate the noise. Mine and the previous poster on F10.5Post definitely had noise from the front of the car and both drive F11s. The rear suspension is self levelling on the F11 so quite different from yours but the front is the same. We drive these expensive cars and I don't expect any type of knock but in my case BMW think they have found the problem. I'll see when I pick the car up on Saturday as they are replacing a front suspension wishbone.
Old 09-13-2013, 10:49 AM
BigDeep1's Avatar
Festaholic
Honestly, my noise was not that bad. I wanted to make sure that nothing was structurally wrong.
I just heard back from service that they could not find anything wrong. Oh well, that is all I really wanted to know.
Old 09-13-2013, 04:21 PM
EIAlfonso EIAlfonso is offline
Mein Auto: 11 535ix MSport w/ Dot
I've had it, it sounds like you're going over a log. I took it in and they told me couldn't replicate
It often happens when I go over the crown of the street at 30-40mph and the suspension suddenly drops down.
It's very annoying and it happens about 10% of the time over the same bump at the same speed, you have the active suspension, ARS?
Old 09-13-2013, 04:26 PM
BigDeep1's Avatar
Festaholic
Perfect description. Fully agree.
I do not have ARS.
Old 09-14-2013, 01:09 PM
Your Welcome...
It took me a long time to find that - I didn't know there was a compartment up there so that made it really funny when I found it....
I hope that is a perm fix for your situation
tk
Old 09-15-2013, 11:09 PM
The technician couldn't see anything obviously wrong but he changed the tie rod end and the lower wishbone (the one the shock absorber attaches to). He test drove the car and said he didn't really think there had been a difference. I've been out for an extended test drive and I think it is slightly better. Now the only time there is a knock is if the surface of the road suddenly dips and it sounds like the shock extends to its fullest and knocks at that point. The technician has offered to come and pick the car up from my house to take it back to BMW if I am still not happy. Think I may take him up on the offer.
Old 12-03-2014, 12:26 PM
Luwester Luwester is offline
Mein Auto: 535xi
Rear Right Wheel Thump over minor bumps
I too have this highly annoying issue. It is difficult to reproduce. I've observed it over the last 6 months, driving on avg. 250 miles/week and encountering these loud thumps coming from my rear right wheel once or twice a week.
I've the following observations:
- mostly encountered while driving under "comfort mode" with the dynamic handling package at 30-40 mph
- road protrusion bump of at least an inch in height may cause an extremely loud thump
- do not think it's any loose object as it's too immediate to be from a bounce
I've found a bump which I was able to reproduce this thump on a highway 5-6 times in a row, and then no longer. It seems highly inconsistent when I may get this disturbing thump. Dealership checked it out 3 times and each time was unable to reproduce the issue. If anyone has had any luck addressing the issue, please let me know!
