Old 09-09-2013, 10:23 AM
BMWMANII BMWMANII is offline
Mein Auto: X3
Codes 0170 and 0174
showing for codes 0170 and 0174 - E83 X3 145K miles
engine sounds rough ride is a bit sluggish
What's the first place to look , Air Filter, Spark Plugs MAF sensor or valve stem seals ?
Old 09-09-2013, 10:31 AM
simsima325 simsima325 is offline
Mein Auto: 2007 X3 3.0si
M54? Check inlet tubes post-MAF for common cracking.
Old 09-09-2013, 10:32 AM
timarnold timarnold is offline
TA
Mein Auto: 2003 bmw 525i 2005 X3
First Place to look is for vacuum leaks. A couple of typical leaks are: Cracked intake boot, particularly where the "Y" for the ICV spilts off, any of the 4 CVV hoses - since you have an E83, if they haven't been replaced the either are cracked or are going to shortly and the vacuum line that runs to the back of the engine to the Seconday Air Control solenoid. Happy hunting!
Old 09-09-2013, 10:44 AM
Mein Auto: X3
yes M54,
thanks for the replies - cracks definitely sounds like it could throw off sensors and causing lean code
