E34 (1989 - 1995)
Old 09-09-2013, 05:29 PM
Dswinty1 Dswinty1 is offline
Mein Auto: 1989 525i
M20 Valve Cover Replacement First Time
I need to replace my valve cover gasket and I bought one on line. It has a silicone bead around the entire gasket except in front of the bolt holes. There is about a 1/2" skip at each hole. Do I need to use a sealant at these areas? Pelican parts didn't know. If so, what would you recommend? This is the first time I have had this off.
Thanks much.
Old 09-09-2013, 07:04 PM
Robinson Crusoe Robinson Crusoe is offline
Mein Auto: 1994 530i 195k miles
did you buy OEM?
Old 09-09-2013, 07:07 PM
also: rule of thumb, unless the shop manual tells you to use sealant, no sealant is needed. Gaskets tend to do their job pretty well
Old 09-09-2013, 09:20 PM
yes, I bought OEM. I can't find anything in the Bently manual about using sealant at those areas. Maybe the compression of the bolt is enough at those areas. Be nice to confirm.
That's for the reply.
Old 09-09-2013, 10:28 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
no need, just put it on. torque it down pretty lightly, the bolts arent that strong, i think its 10Nm but i could be wrong, its not much anyways.
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
