2009 328xi Rear Shock Mount Broken - Bimmerfest - BMW Forums
Old 09-09-2013, 07:16 PM
jw007 jw007 is offline
Mein Auto: BMW 328ix
Question 2009 328xi Rear Shock Mount Broken
My local dealer is telling me that one of my rear shock mounts are broken and is telling me that both rear shocks, mounts, and bumpers need to be replaced at a cost of $975, can't the mount just be replaced without replacing both shock assemblies?
Old 09-09-2013, 07:44 PM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
If the lower shock mount is broken, it is likely due to a worn out shock. That is why he wants to replace both. Bumpers are probably jsut an upsell unless he is talking about the rubber grommets on the shocks.
Old 09-09-2013, 07:54 PM
Thanks for the input, I was just a little concerned that the shocks could wear out within 30k miles, seems like a design issue.
Old 09-10-2013, 02:51 AM
mr_bean mr_bean is offline
Mein Auto: 2000 328i
I have to disagree that a worn shock would cause a mount to fail. To the contrary, if the shock is worn out, it will put less force through the mount thus making it last longer.
This is more likely then not a manufacturing defect in the shock mount, not a design flaw. Take it to another shop for a second opinion. I think you only need one new mount and nothing else. There's no reason to replace all those parts on such a low mileage car.
Old 09-10-2013, 03:32 AM
That's what I asked the service manager as I thought the mount alone could be replaced but he says that the shocks should be replaced when the mount is replaced as well, seem a little unnecessary and expensive.
Old 09-10-2013, 04:53 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Wouldn't you want to get a second opinion?
But, hey....working blind here. Kindly post pic of issue.
It's the little things. Like....
  • Upper or lower mount? That could make a difference.
  • How is it broken?
  • Why do shocks need replacement?
  • Stock shocks or aftermarket?
At this point, pic's worth a thousand words.
Old 09-10-2013, 01:55 PM
Mein Auto: '06 AW 330xi
The dealer is "trying" to save you on labor costs. Shocks/strutrs normally need replacement every 60k miles depending on road condition and driver habits.
With the rear suspension already disassembled, it will save you money in the long run to swap out the shocks since they will have to be removed to replace the mount.
Just FYI, you should always replace suspension components in pairs, left and right. So if only one shock mount is broken, you should still replace the other side.
Take your car to a indy shop. They will be a bit less but then you have to get a loaner or wait around for the work.
