Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F07 Gran Turismo (2010 - 2017)
The 5 Series Gran Turismo - 535i, 550i and 550i xDrive model.
Old 09-10-2013, 11:39 AM
katiesdad7 katiesdad7 is offline
Mein Auto: 2011 550I GT
Got the new tires
Got the car back from the dealer yesterday with the new Michelin A/S 3. Car rides really smooth now and real quiet. I got a slime inflator kit from Amazon in case I get a flat or leak.
I recommend these tires. Thanks to all who helped me make this choice.
Old 09-10-2013, 02:56 PM
jadnashuanh jadnashuanh is online now
Mein Auto: 535ix-drive GT; i3 BEV
FWIW, Slime may clog the TPMS, should you ever need to use it, and then add the cost of a new one to the price of the repair. Tire shops may also charge extra to clean up the mess inside as well.
Old 09-10-2013, 03:57 PM
It was recommended by the BMW tech. I can see it causing problems with the TPMS. I have found that most of the time its a leak due to a nail or something like that. In that case I can just inflate the tire to get me home or to the repair shop. At least that's my theory. Worst case is that its towed to the dealer and fixed. I have Good Sam and they will tow it to the nearest dealer. I don't think the tow would be covered under warranty.
Old 09-10-2013, 04:22 PM
If the hole is big enough (rare), the only help is to change the tire which would likely require a tow. And, I think you're right, the BMW service would pay for a mechanical fault (say engine) but not a tire related one, since you should still be able to drive with the stock tires.
HTML code is Off
