Old 09-10-2013, 02:28 PM
tohbi tohbi is offline
Mein Auto: z3 '97 atlanta blue 2.8
z3 throttle body
what do y'all know about aftermarket throttle bodies from riot racing? price isn't bad if the performance increase is what they say it is.
http://www.westcoastriots.com/obd2.h...CT_ID=18601765
link for all: http://www.westcoastriots.com/
Old 09-17-2013, 11:38 AM
what, no one has replaced a throttle body? it's a common way to improve fuel flow on many cars.
Old 09-17-2013, 03:15 PM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
The general consensus here is that the BMW engineers did a pretty good job of balancing the system. A bigger throttle body can only help if it is the most restrictive part. It is not. It is one of many parts, such as MAF. manifold, valves, cams, ports, headers, exhaust pipes, cats, and mufflers. The only way to add any meaningful horsepower to these engines is to add forced induction.
If you do a search here on Performance Mods, you'll generally find that sentiment from others who have tried many things.
I believe there is absolutely no way a bigger throttle body (with 7% larger bore) can increase air flow by 11% and WHP by 8% as claimed. There just isn't that much margin left in the system.
That being said, I have never heard of anyone replacing just their throttle body. Perhaps you would be willing to buy one, install it, and get it tested on a dyno for us. Post your results.
Old 09-18-2013, 02:53 PM
i understand what you're saying but any improvement in airflow is, well, an improvement. while this throttle body claims to be 4mm wider, it also has a refined butterfly. it's common for people to take an existing throttle body and knife-edge the butterfly to reduce turbulence thereby increasing air velocity. polishing the throttle body walls and matching mating surfaces also are common.
the dyno graph that claims almost 8hp increase also had a dinian chip and track pipes on the car. riot racing says most improvement is in the 3-5hp range. they show a couple other dyno tests that are in the 4 and 5hp range [if i understood them correctly].
but there's more than horsepower to consider. quicker, smoother throttle responses are others. moreover, they claim no loss of torque, which seems sensible to me. at $250 [doing the change yourself] it seems a logical expense considering how much some of us spend on exhaust systems, et al.
here's a thread: http://www.bimmerfest.com/forums/sho...d.php?t=403389
Old 09-18-2013, 08:07 PM
Christian's Avatar
Christian Christian is offline
Project No Budget 1.9
Mein Auto: 1997 Z3 1.9
I don't know anything about that particular supplier, but I had the original TB on my supercharged 1.9 bored by MaxBore (http://www.maxbore.com). If I recall the cost was only about $80 and the service took a few days. It looks like their current pricing is up to $99.00. At the prices they charge I don't see how you can go wrong with MaxBore.
Old 09-28-2013, 04:02 PM
what did boring do for performance? did you have the ports matched too? thx
Old 09-29-2013, 08:36 AM
Z3Papa Z3Papa is offline
Mein Auto: 2002 Z3 3.0
Dinan used to have big bore throttle bodies for your car and others. It's been a while since I was on their site but the performance bump wasn't huge.
2011 BMW M3 ZCP in Melbourne Red, Apex wheels (ARC-8 and EC-7's) with Bridgestone RE-71R's.
