Old 09-11-2013, 03:48 PM
andrewkpt andrewkpt is offline
Infamous06
Mein Auto: 2006 bmw x3 3.0i
Fog light Help
after searching and finding little no answers on how to do i need help.. i am trying to replace my fog light bulbs on my 06 x3 and im not sure if i should tug the fog light cover off since there is not bolts or try to access from behind anyone please help
Black
Mans
Whip
Old 09-11-2013, 05:49 PM
Burning2nd's Avatar
Under the lift arms
From behind i assume.. like every other bimmer?
thats normally how they do it..
it should twist off.. and the socket will have the bulb in it
and or the socket might pull away and the bulb will remain with a metal clip for the h2 bulb types
15486372<-----
Old 09-11-2013, 06:38 PM
joylove joylove is offline
Mein Auto: 08 e83 LCI
Always from behind. BMW haven't done front access in 20 years. Check the owner's manual for the detailed instructions.
Old 09-12-2013, 01:51 PM
Infamous06
ok thanks more insight if anyone knows
Black
Mans
Whip
Old 09-12-2013, 03:09 PM
CT-X3 CT-X3 is offline
Mein Auto: 2007 X3
there's a how to on you tube......looks pretty simple - http://www.carcarekiosk.com/video/20...lights/foglamp
Old 09-12-2013, 04:27 PM
Infamous06
as stated above i have a 06 and my fog lights are different
reading rules.............
Black
Mans
Whip
Old 09-12-2013, 08:13 PM
CGL CGL is offline
Mein Auto: 2004 BMW X3 3.0i
- Look straight at the light housing and see if there's a small opening/gap on top (12 o'clock) between light housing and the fog light trim.
- if so, use a plastic wedge piece to unclip the trim through that opening. Then, remove trim from bumper (NOTE: There are 4 retaining hooks on the back of the trim, 12/3/6/9 o'clocks...try not to damage those).
- Remove the 3-4 exposed screws.
- remove the fog lamp (try pushing it inwards a little bit, first).
If you don't see opening at location mentioned:
- use plastic wedge and carefully force a gap between housing and trim.
- be careful not to break the housing trims (these are at 1/5/7/11 o'clocks)
- remove the exposed screws
- push lamp inward a bit and pull out.
Old 09-13-2013, 11:53 AM
Infamous06
well heres the thing:
on the front of the my bumper on the fog lights there is a cover with a small hole on it. i stuck a screwdriver in there but there is not bolt ..... so then i tried gently pulling off the cover but it seems like something is holding it. i ultimately wanna know if i can do anything before trying to remove the front bumper ( which i have no idea to do )
Black
Mans
Whip
Old 09-13-2013, 12:09 PM
CGL CGL is offline
That's b/c the trim is held on by that clip! I mentioned in step #2 that you needed to unhook the clip (push up or down). The fog lamp is held on by screws, which is covered by the trim...once the trim is removed then you will see the screws. Have fun.
Old 09-13-2013, 12:19 PM
Mein Auto: 2007 X3
not sure if this is exactly the same as your fog light layout but looks similar
Old 09-14-2013, 10:10 AM
Infamous06
thats actually mine.. thanks a million
Black
Mans
Whip
