E90 2007 Voltage dips - Bimmerfest - BMW Forums
Old 09-11-2013, 04:45 PM
cokewithvanilla cokewithvanilla is offline
Mein Auto: 2007 BMW 328i
Hello
I have a 2007 e90 with some voltage issues. The voltage when off is 12.4. When running at normal speeds it's between 13.7-13.9. When I am driving at low speeds in stop and go traffic (mainly when braking hard), the voltage often dips to 12.4. Around 15mph, 500-700rpm, the voltage will dip to 12.4 and the AC will slow down then speed back up.
I replaced the battery 6 months ago. I do not think the battery is the issue as it has proper voltage when off. Is this a voltage regular/alternator thing?
One more note... recently I did a hard stop from 80 to 0. The car shut off.
Old 09-11-2013, 06:20 PM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
I think the shutting off is unrelated to your issue. Here is what the service manual says.
Ignition off at battery should be 12.6v
Engine running should be between 13.5 and 14.5v
Run engine at 2,000 rpm. Turn on fan, rear window defog, wiper and lights, etc. With all accessories on voltage should be 12.6,
Engine running, battery charged accessories off is usually between 13.2 and 14.5
If it is over 14.8v you have a faulty voltage regulator.
I think your alternator is fine based on your post.
Old 09-11-2013, 06:26 PM
Ok. Is the fan supposed to drastically change speeds based on engine rpm? The voltage dips at low rpm to the point where the ac slows enough that you really notice. This doesn't seem to be normal operation.
Old 09-11-2013, 07:04 PM
It is. The power management system can reduce or shut down electrical loads when the alternator can't keep up. This could happen at idle with the blower on. It uses as fair amount of power.
If the battery charge status is critical and the alternator is at maximum input then the blower motor is reduced to 75% then 50% then 25%. So that being said, your battery shouldn't be critical unless it is old.
Old 09-11-2013, 07:58 PM
So it slows down, then speeds up immediately. It doesnt even register the change on th climate control. If the battery were bad, this would make sense, right? But the battery isn't.
Old 09-11-2013, 08:14 PM
Mein Auto: '06 AW 330xi
Did you have the battery cable recall done?
Also how are you monitoring voltage while driving?
Old 09-11-2013, 09:08 PM
I have not. Would this be covered at 114k?
Using test 9 on the dash
Old 09-12-2013, 08:09 PM
Yes, if your car's VIN falls under the recall.
