Old 09-12-2013, 05:40 AM
K-Fish K-Fish is offline
Mein Auto: 2005 X3
2005 X3 lowering problem-alignment
In need of some feedback from those who have used the H&R/Bilstein springs replacements.
A few months ago I had all 4 springs and struts/shocks relaced on my Wife's 2005 X3 3.0 standard model due to broken coils. I used the H&R50433 and Bilstein HD shocks 114585 and Bilstein struts 114567 and 114574 as spec'd from Tire Rack but purchased elsewhere due to 3 month backorder from TR.
After replacement the car has a very noticeable negative camber stance. I took the car to a reputable shop and the said the alignment could not be brought in to factory spec and did not charge me anything for the attempt.
I decided to leave it alone as I was told this modification does not require any additional kits with the install, and proceeded to drive it as is.
We now have extreme wear on the inside edges of all 4 tires and need to replace them. I don't want to buy tires until I solve the alignment isuue.
So my question: who has done this package and what did you have to do? Is there enough adjustment to get this right or do I need to go back to stock spring dimensions? Spending $300-$500 for correction kits is not an option I would consider. Did my alignment guy miss something?
Old 09-12-2013, 06:23 AM
usaret usaret is offline
Mein Auto: A Gamma Goat
My dad (who was a dealership technician for 38 years) had a couple of customers accuse him of making matters worse when he tried to be a nice guy and try to align their modified cars. As a result he took a stand and refused to work on anything that appeared to be modified in any way. Several of his fellow tech's took the same stance on the issue. So you're kit may have put the adjusters out of range or they may just be afraid of it.
Another negative of modifying is that they bury you on trade-in as the dealership normally will not take the risk of selling them so they go straight to the auction.
http://www.justice.org/cps/rde/xchg/...8070_18111.htm
Old 09-12-2013, 08:03 AM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
So you lowered it with H&R's
you put the wrong spings on the truck..
you have a non sport model and you put sport aftermarket springs on it..
15486372<-----
Old 09-12-2013, 08:27 AM
nightmareuki nightmareuki is offline
Mein Auto: X3
looks like you used the wrong springs,
http://www.tirerack.com/suspension/s...Standard+Model
Old 09-12-2013, 03:54 PM
Mein Auto: 2005 X3
Nightmare-I gues I am not seeing your point? The link you posted says 2005 x3 standard model and lists the spring I used.
As for the shop wanting to stay away from the alignment, it was a friend and he did attempt to do it, but at the full range of adjustment it was still out. He showed me on the alignment computer.
I would have used stock spring height, but the improved stance sounded like the way to
go as that was what everyone was offering.
Old 09-12-2013, 04:03 PM
Mein Auto: 2005 X3
I think the H&R and Eibach springs are comparable in length, so I would welcome input from anyone that used the Eibachs as well.
Old 09-12-2013, 04:33 PM
Burning2nd's Avatar
Under the lift arms
Ok so if you dont want to chew tires up... you have 2 options..
camber kit.
different spings
simple problem
15486372<-----
Old 09-12-2013, 04:46 PM
Mein Auto: 2005 X3
Burning, I'm new here but...If I wanted info from a Jackass I would have said " Hey Jackasses, what do you think"
I used a kit that is proposed by Tire rack and others to be a direct replacement for defective factory springs with the added benefit of improved handling. I would like to hear from others who have used this, and don't need any feedback from guys like you. Thanks.
Old 09-12-2013, 04:49 PM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
Re: 2005 X3 lowering problem-alignment
I've installed eibach pro kit springs along with Bilstein hd shocks and struts. So have a few others on this forum. My advice would be to go to a BMW dealer for the alignment. Tell them what work was done to the suspension. The alignment is the only reason I will go to the dealer. It should be easy for them to get to factory specs on the alignment. As long as the vehicle hasn't been lowered more than an inch.
Old 09-12-2013, 05:29 PM
Mein Auto: 2005 X3
Mlukas, When I orderd the springs I thought the H&R and Eibach were comparable, and according to Tire Rack they are. 1.2" front-1.2" rear for the Eibach, vs. 1.3" front 1.2" rear for the H&R. These are the springs they list for the standard model. I read your posts last night and you stated no problem with alignment, so that's why I question the alignment shop.
Not sure where to go from here. Did you take before and after measurements?
Thanks.
Old 09-12-2013, 06:08 PM
Mein Auto: 2005 X3
I have heard broken coils are common on this vehicle. Since there has not been much response to my aftermarket post did most people with this problem just go to the dealer and give them the $2200-$2500 for stock repairs?
Old 09-12-2013, 07:13 PM
Mein Auto: 2004 X3 2.5i
Lesjofors have been used by some X3 owners. Same height as O.E. http://www.ebay.com/itm/BMW-E83-X3-2...dddeac&vxp=mtr
Not sure if that is the best available price.
Kilen is another brand but don't know if they do an E83 spring.
BTW, it is just the rears than tend to break.
Old 09-12-2013, 07:46 PM
mlukas161's Avatar
Thanks.
My gut feeling is that you need to take it to a different aligninment shop, preferably a bmw dealer. There is a noticeable negative camber on our X3, however alignment is within factory spec and we have no unusual tire wear after 25,000 miles. I'm thinking you need a second opinion.
Old 09-12-2013, 09:33 PM
leadboot leadboot is offline
Mein Auto: 328Si
actual amount lowered
The link provided by nightmare shows the following note for the HR springs.
"Stock ride comfort is retained while a lowered ride height between 1.25 1.8 on average can be expected."
Maybe the springs installed lowered your X3 more than 1.2". Probably good idea to get measurements off another standard X3 to compare to your current ride height. BMW dealer probably could help with those measurements and let you know if they could get alignment in to spec with the HR springs.
Old 09-13-2013, 04:10 AM
Mein Auto: 2005 X3
I did find the Lesjofors while searching for some stock height springs. Are they a quality spring? That might be my best option.
I did not want to take it to the BMW dealer here for the alignment because they were the ones who noticed the broken spring and a blown strut and wanted $2200 to do the repairs (2 rear coils and 1 front strut). That's what got me looking at aftermarket. I had all four corners done with labor for $1500.
I figured if I took it to them with the H&R's they would tell me they couldn't align it beacause it wasn't stock. My dealer is 60 miles away and I don't have another one nearby that I can go to for the alignment.
I did not notice if the car started with some negative camber to begin with. I did not take any measurements beforhand because I did not expect to have a problem.
Unless I hear from others with the same kit I will give another shop a shot at the alignment before I replace the H&Rs with the Lesjofors.
Old 09-13-2013, 07:45 AM
OK. I was just throwing it out there as some shops would rather tell you they can't than to tell you they won't and risk pissing you off. I hope you can get it sorted out.
Old 09-13-2013, 09:16 AM
Burning2nd's Avatar
Under the lift arms
U can get oem springs off eBay for 75$ a peice
15486372<-----
Old 09-13-2013, 10:49 AM
Mein Auto: X3
Front and Rear fitment
Ride Height: Moderate Lowering
Avg low 1.3"F 1.2"R
Read the model spec not whole product range specs
Old 09-13-2013, 11:00 AM
Mein Auto: X3
according to amazon
H&R 50433 Sport Spring
Sport Spring
Front lowering: 1.6 inch
Rear lowering: 1.5 inch
vs
Tirerack
Avg low 1.3"F 1.2"R
Old 09-13-2013, 06:18 PM
Mein Auto: 2005 X3
Sorry Nightmare, I still don't see where you're going with this. The springs are listed for the standard model x3. This is supposed to be the part number for springs that should bolt up with no other mods according to the sales person I spoke with. It is not the kit for the sport model, which is 29378-2, according to TR.
Old 09-13-2013, 06:57 PM
Burning2nd's Avatar
Under the lift arms
DUDe you bought the wrong springs...
you yelled at me cause your "new"
you didn't want any advice?
whats the problem
you have the 2 options
i tried to tell you kindly what you needed to do.. and you yelled at me... and then we are still here disusing your wrong purchase
**** or get off the pot...
new CORRECT NON sport model springs..
OR!!!
camber kit
15486372<-----
Old 09-14-2013, 04:49 AM
Mein Auto: 2005 X3
I asked for feedback from someone who has used these springs and your response was to say that I ordered the wrong ones. I have shown the part numbers for the standard model X3 and the sport model X3. I ordered the springs for the standard model as per the Tire Rack sales persons recommendation. I realize the springs are NOT the origional Stock length, and never thought they were.
They are NOT the springs for the Sport Model-Look it up on Tire Rack. When you can show me a link that states the 50433's are for the 2005 BMWX3 Sport Model I will apologize for yelling at you.
Old 09-14-2013, 09:58 AM
Burning2nd's Avatar
Under the lift arms
http://www.tirerack.com/suspension/S...=Sport+Package
there ya go boss..
you orderd those? for a 05 2.5
2nd one down..
SPORT PACKAGE
what do you have a 3.0?
http://www.tirerack.com/suspension/S...kage+Staggered
Or these...
anyway... back to the point... we should be focusing on how to fix the problem... not what caused it
15486372<-----
Old 09-14-2013, 10:47 AM
As to the suspension components difference between the Sport and non-Sport 2005 X3:
- the part nos. for the shocks, struts, sway bar, bushings, and springs are different
- for the springs the difference is in spring rate, not length of spring (or ride height)
The 50433 Sport spring is H&R's designation for their base spring, the next level being a Super Sport spring.
The amount the 50433 will lower the 2005 X3 (whether a X3 std. or X3 Sport) is an estimate on H&R's part.
Previous posters have found this to be as much as 2" (that could be a be rounded up estimate) - see posts # 8,9,10 and 11 in:
http://www.bimmerfest.com/forums/sho...d.php?t=451386
Old 09-15-2013, 06:11 AM
Mein Auto: 2005 X3
Supercourse, thanks for that link, that is the thread I wish I found when I was searching my problem last week. Madurodave is stating exactly what I suspected, you must use camber correction to use these springs. That should be known and told by Tire Rack when you order them.
I see now that they list the same spring for all the models of my X3. The number I posted above for the sport model was for an X5, a slip of my fat finger in the pulldown menu.
Since Mlukas isn't having any issues then the Eibachs must not lower the car as much as H&Rs. I debated back and forth before purchasing and bought the H&Rs in the end because the majority of the posts I read comparing both said the H&Rs would be a bit more comfortable than the Eibachs.
At this point I am not going to risk wasting more money to try to make these work. I will go back to a stock height spring.
would I be correct in assuming the Bilteins I bought will work with the stock height springs?
