Old 09-13-2013, 07:48 AM
tommygunzbmw tommygunzbmw is offline
Mein Auto: 07 BMW 328i Built 04/2007
INPA Transmission Error
I am trying to scan my transmission module in INPA but can seem to get it working
I have attached a picture of the module I am selecting and the error i get when I do.
Any help would be greatly appreciated.
ID:	396590   Click image for larger version
Old 09-13-2013, 08:58 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
Are your daten files uptodate enough.
http://www.e90post.com/forums/forumdisplay.php?f=368
or bmwcoders.com
Old 09-13-2013, 09:06 AM
Iam not sure if they are up to date do you know how to update them in inpa? I was lead to believe you cant update daten files in inpa?
Old 09-14-2013, 03:56 AM
mr_bean mr_bean is offline
Mein Auto: 2000 328i
Which cable are you using? Are the #7 and #8 pins shorted or open? They need to be either open or shorted depending on the particular D-bus network installed in your car. I'm not sure off the top of my head which way it needs to be for your model year.
Also, make sure the cable is plugged into both the car and laptop BEFORE starting up the INPA software. You'll know everything is connecting correctly when both the "Battery" and "Ignition" say "on" at the top of the welcome screen.
You probably don't need to update the daten files, but if you do rest assured it's possible. You can find more info at www.bmwcoding.com
Old 09-14-2013, 04:38 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
You'll get a focused response in the coding forum, or check a coding site....
Old 09-14-2013, 10:05 AM
As far as I understand it Inpa uses daten files.
Inpa makes calls to the daten folder for the files it needs
for various modules and there proper revision numbers if they are not
there if throws and error. The subject of updating and getting the latest
daten files is a constant topic on the coding boards.
With and 07 your files shouldn't have to be that new.
Old 09-15-2013, 08:13 AM
Mein Auto: '06 AW 330xi
You don't have the right files in your Ediabas/ECU folder.
If this was an issues with PIN assignment, it would be a comm error. IFH-0009, connection to interface disturbed or whatever.
BTW datens are used for NCS Expert. I forget what the files for the ECU folder are called....indexes?
328i, coding, e90, inpa, scanning, transmission
