The X5 SAV Forum
Old 09-14-2013, 07:02 AM
skptc skptc is offline
Mein Auto: 03 Z4, 04 X5
EONON D5124FU in my 04 X5 4.4?!?!?!
This thread is to document my hopefully ultimately successful attempt to put an EONON D5124FU in my 04 X5 4.4 (mid, no nav, no changer)
Below is a link to the unit listing on eBay where you can see in the description it claims to be a simple 20 min diy and a direct perfect fit for the e53.
The item was listed as available but as soon as I paid i got a message that they were out of stock. Ended up waiting almost two weeks for it to ship. (Btw you will get a separate bill from the shipping service fur import duty into the U.S.).
Unit comes in a plain white box with no instructions at all. When asked I'm told its such a simple plug and play no instructions are needed.
To be continued...
http://rover.ebay.com/rover/0/e12052...AMOTORS%3A1123
Old 09-14-2013, 07:30 AM
Re: EONON D5124FU in my 04 X5 4.4?!?!?!
As soon as I pulled out the MID And CD player I knew something didn't look right.
Although the outer dimensions are right and the body slides into the factory cd slot the eonon is flush at the top but the factory cd is not so the only way to fit it properly is to cut out the upper cross member of the plastic frame in the dash. S mod I'm reluctant to do until I'm certain the unit will otherwise work.
One of the harnesses provided matches the 40 pin factory harness that his into the cd but there is absolutely no provision for the MID connector.
Once connected by itself the unit does not turn on at all unless the MID is plugged back in in which case it turns on but no sound at all
(It's in this testing phase that I reconnected the MID with the key in the 1 position apparently killing it)
So at this point I need to figure out how and where to connect the unit and whether I need to keep the MID plugged in for it to work in which case I guess it needs to go on the glove box?
So far seller has been off no help at all other than suggesting I need an extended harness to make the connection in the back where so far I haven't found any 40 pin connections
ID:	396821   Click image for larger version
ID:	396822   Click image for larger version
Old 09-14-2013, 08:53 AM
puddinboo puddinboo is offline
Mein Auto: 2003 BMW X5
i think you will have to hide the mid somewhere like the glovebox, as for a 20 min install that doesn`t sound right at all ,thats just a sales pitch (salesman are liers I work with them everyday in the health care feild ).
Old 09-14-2013, 09:10 AM
heres a link for you hope this helps ya out .
http://www.bimmerfest.com/forums/sho...d.php?t=716255
Old 09-14-2013, 09:35 AM
heres bmw wiring color codes for hooking up stereos hope this helps out.
http://www.modifiedlife.com/2004-bmw...ire-schematic/
Old 09-14-2013, 09:53 AM
heres the eonon site http://www.eonon.com/Car-GPS/Specifi...MW/D5124F.html
Old 11-18-2013, 03:12 PM
sesmith72 sesmith72 is offline
sesmith72
Mein Auto: 2003 E39 Sedan
Any update on the install? Waiting to install my D5124 but finding that NO ONE KNOWS HOW TO DO IT???!!! Not even the Manufacturer.
Old 11-20-2013, 02:43 PM
I started a new topic to see if I can reboot the conversation. So far I have the unit in place and it turns on but no sound...
Old 11-20-2013, 03:00 PM
sesmith72
I got mine installed...reading all the stuff about DSP freaked me out. Luckily NO DSP on mine. My only remaining issue is the fade/balance is off and I don't want to modify the harness.
Old 11-23-2013, 10:34 PM
KyleNatoliX5 KyleNatoliX5 is offline
Mein Auto: X5
Now I'm second guessing getting this...
Old 11-26-2013, 10:52 PM
sesmith72
http://www.xoutpost.com/bmw-sav-foru...rough-diy.html
Easiest to understand DSP workaround I have seen.
Old 01-06-2014, 08:54 AM
Qui_Luv Qui_Luv is offline
Mein Auto: 2006 X5
2006 X5 w/ Navigation
Will the Eonon work for my 2006 X5 w/ Navigation? I really want a new stereo but am scared to purchase this off ebay, then have to pay for shipping back to hong kong if it doesn't work. Any suggestions?
Old 01-06-2014, 01:19 PM
DDutchman DDutchman is offline
Mein Auto: 2005 X5 3.0i
Eonon D5124F
The D5124F will "fit", and some functions might work as long as you use the A0565 cable if your radio receiver is in the tire well and you do not have the DSP amplifier. You will likely not receive any helpful customer support, but you will get promises.
I got rid of my unit after a month. Many of the eBay sellers are actually Eonon fronts. I have it in writing from Eonon. It is very easy for them to ship to you from HK. Let me know if you ever get an RMA to send something back!
Caveat Emptor
Old 01-13-2014, 01:39 AM
mik15 mik15 is offline
Mein Auto: '06 750Li
i bought a unit from Eonon for my ex. E39 which had the factory 16:9 display and system, honestly i wouldn't buy it again, spend a little extra and get the Dynavin which is way better than this one, even though they're both Chinese, the latter one is much better. The Eonon has a slow software and not all functions will work as they advertise it plus installation turns out to be a PIA unlike what they claim. Sold the car to a friend of mine and he isn't very happy either about this unit, so i would say stay away from it, it is cheap indeed but still doesn't worth the money you pay for it IMO.
Old 01-28-2014, 10:28 PM
Mein Auto: 2006 X5
What's a RMA?
Old 01-28-2014, 10:37 PM
return auhtorization for returnning parts under warranty
2003 X5 3.0i
