Old 09-17-2013, 03:45 PM
roberzan roberzan is offline
Mein Auto: 328i Coupe
TPMS Reset for original set of wheels
I've decided to outfit my 328 with a second set of wheels, keeping the originals intact for spring/summer driving.
My question is, will the originals reset with the TPMS after being off the car for several months or will I need to go to the dealer or tire center to change the wheels out and re-activate the TPMS sensors?
Would rather change them out in my garage if possible. Thanks!
Old 09-17-2013, 05:09 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is online now
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
No worries, they will be fine. Shortly after the first time you start the car after swapping wheel sets, the car will alert you that TPMS needs to be initialized. Follow the normal reset procedure and Bob's your uncle.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 09-17-2013, 06:24 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
Zeichen is correct. The TPMS will "go to sleep" when not being used (no tire rotation). So your second set of wheels will not have TPMS installed? Therefore you'll get a dash "malfunction" indication I believe.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 09-17-2013, 06:30 PM
Mein Auto: '06 AW 330xi
This depends on model year. If you have a car built before March '07, your car has FTM which uses the ABS sensors in your hubs to calculate rotational speed of the wheel.
Post March '07 models utilize the TPMS system, which uses sensors in the wheels and receivers in the wells. TPMS sensors have non-replaceable batteries and they do fail after a few years.
There was also a change in sensor frequency sometime in 2009. So make sure you get the right sensors.
Old 09-17-2013, 06:32 PM
Btw if you're interested, TPMS can be coded off. Remove the option code from your VO, code the affected modules, pull TPMS fuse in glove box, and unplug module in trunk.
Old 09-17-2013, 09:23 PM
pointandgo's Avatar
IIRC, it was 9/09.
OP: What is the year of your car?
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 09-18-2013, 06:28 AM
It's a 2009. Saw the posts about the part number changeover in September 2009. Will check the manufacture date. Yes, new wheels will have factory TPMS installed. Going with aftermarket, factory spec. Getting 5, as I do a lot of driving on secondary roads (more turns, less traffic) and don't want to have to nurse a run-flat home.
Appreciate the responses!
off car long term, reset, tpms
