Old 09-18-2013, 08:34 AM
ottawae91 ottawae91 is offline
Mein Auto: 2006 E91
radio interferance when rear defroster on?
just picked up a 2006 E91. So far the wife and i are very happy with it, beautiful car. one peculiar thing i have noticed now that it's getting a bit nippy in the mornings is that when the rear window defroster is turned on, the radio reception goes to crap.
clearly there's some electrical issues there... this is my first BMW, i cut my teeth on a succession of VWs and Audis. before i go n bust up the interior, can someone provide guidance on where to look and any suggestions on the root cause?
otherwise the car is pretty much functionally flawless
thanks
Old 09-18-2013, 08:42 AM
mossman35 mossman35 is offline
Mein Auto: 2016 340 Xdrive Msport
Not sure how the 2006 models are, but the newer ones have a thin film FM antenna affixed to the rear window.... close to the rear defroster. Do you have an actual antenna on the hood of your car? If not, it might be coupling going on between the two on the rear glass. Not sure what you can do about it in that case. I would be curious if other owners have similar complaints.
If this is not normal for this year, the other issue would be electrical noise coupling within the electrical system. Probably ground issue. Not easy to find.
I realize I am not helping much but these are the two starting points I would use if I had the car in front of me.
Old 09-18-2013, 08:54 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Noise in the DC defroster signal'll induct interference to your FM antenna. Prob an ailing connector.
Old 09-18-2013, 08:56 AM
Mein Auto: 2006 E91
My car has a small sharkfin antenna on the roof. sincerely hope i don't have the film atenna as you describe as i would think my only solution is a new hatch glass.... which i'm sure is very cheap.... right?? RIGHT?!?!?!
only noticed it the other morning, so much investigation yet to be done.
Old 09-18-2013, 09:11 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
The sharkfin is not the radio antenna.
http://www.e90post.com/forums/attach...2&d=1260829447
Old 09-18-2013, 09:13 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
The shark fin houses the satellite and telephone antenna. The FM antenna is in the liftgate.
Is the rear-window defroster the only accessory that causes the problem? What happens if you turn off the defroster but turn on as many other electrical loads as you can (e.g., seat heaters + headlights + HVAC blower to max + wipers)?
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 09-18-2013, 09:36 AM
Mein Auto: 2006 E91
balls. ok, will take a close look at things to see if there's anything obvious. my guess is though that glass will not be needed as if the antenna was pooched, reception would be bad all the time... hopefully "just" the filters or bad grounding or sumsuch deal... damned electrons not following direction!
