Old 09-18-2013, 02:29 PM
bmwblack55 bmwblack55 is offline
Mein Auto: Bmw 528 i 2014
Angel eyes recommendation
Please check this link out and let know if it is a good idea for angel eyes for my e60 lci
http://bit.ly/15DBKb0
Old 09-18-2013, 05:18 PM
E92-Lighting's Avatar
Mein Auto: 335i
DTEC V7 angel eyes are the brightest in the world, here are some sample shots
BMW ACCESSORIES and PARTS
Old 09-22-2013, 01:45 PM
Anybody bought angel eyes led bulbs from 'epanda house' on ebay. Any recs. they have '2nd generation 20w 7000k led for ae with cree)
Old 09-22-2013, 10:46 PM
tony925 tony925 is offline
Mein Auto: 2008 535i
I bought a pair very similar in design to those on ebay but they were the CREE BMW H8 32W LED Angel Eyes. Bought them from a "polarbearmotor". I noticed the ones you're asking about are only 20W. Why not go for the 32W (or higher as I see are available) for a few bucks more. Without getting overly obsessive with these bulbs, the ones I got are plenty bright (very visible during the day and have the "white" glow that makes them look like the newer generation halos). Mine don't flicker EXCEPT when you turn off your DRL's. When the DRL's are off and I start my engine is when I can see the halo's flicker upon start up and then turn off. This doesn't bother me as I like to drive with the halo's on (Duh!). The only other qualm I had with the ones I received were that the "key-hole" fins on one bulb was actually machine-cut incorrectly and so it didn't fit into the "key-hole" of the lamp housing easily. I had to push the bulb in at a slight angle before I could turn it back straight again to turn it to the locked position. (Can you say "cheap imports"?) Other than that it's been over 2 months since I've bought them and they work fine. Hope this helps.
2008 535i Platinum Gray
Old 09-24-2013, 11:41 AM
Just wondering when you replace angel eyes bulb . Do you have to remove high beam bulb , which is in same encasing.i.e h7 bulb.
Old 09-24-2013, 12:42 PM
booyaazaa's Avatar
booyaazaa booyaazaa is offline
Mein Auto: '09 AW 535i, Fiat 500e
Do you have halogen or bi-xenon lights? It will make a big difference since the lights posted on this thread so far are for xenon lights. If you have halogen lights it is a different bulb and not a H8 bulb.
2009 AW 535i
-Sport, Premium Package, and Comfort Access
-FBO, custom Cobb E45 map, Fuel_it Stg2 LPFP, Performance Gearing LSD.
Follow on IG: Booyaazaa
Old 09-24-2013, 12:53 PM
Changed bulb my low beam recently . It is h7 so i guess not xenon
Old 09-24-2013, 03:53 PM
No. The angel eye bulbs sit independently on the whole headlight assembly. They are H8 bulbs and just twist out from the back of the assembly. They are hiding behind a plastic lid on the backside of the assembly. Yours should be this way if you have the LCI lights (e60 >2008) You do have to unscrew the headlight casing to have room to replace the bulbs. It was too much trouble for me to remove the entire casing so with my medium sized hands I was actually able to just lift up one side of the casing, twist off the plastic cover, and twist and remove the bulb.
Old 09-24-2013, 04:10 PM
Justin545i Justin545i is offline
Mein Auto: 2004 545i
I want some for my 04 545i that well show I'n the daylight any links?
Old 09-24-2013, 04:19 PM
booyaazaa's Avatar
Hey tony he has halogens so they won't be H8. It will be that wacky bulb BMW uses.
Op - you need similar bulbs like this for your AE. http://www.umnitza.com/umnitza-ice-v...ht-p-6457.html
Just don't expect them to be super bright.
2009 AW 535i
Old 09-24-2013, 08:52 PM
I guess I'm a little confused then. I thought the 2008-10's all came with standard xenon. No?
Old 09-25-2013, 12:31 AM
booyaazaa's Avatar
Nope. Bi-xenons were still an $800 upgrade option.
2009 AW 535i
Old 09-29-2013, 05:53 AM
I have H8 for angel eyes but low and high beam are H7. What led angel eyes bulb i need
Old 09-29-2013, 09:31 AM
Mein Auto: 335i
ours are 64 Watts
Old 09-29-2013, 09:37 AM
Mein Auto: 335i
ours are brighter, we have 4 CREE leds for the E60 LCI with halogen headlights
Old 09-29-2013, 09:38 AM
Mein Auto: 335i
MTEC V3's are the brightest for the pre lci E60's and its daytime visible as well.
Old 09-29-2013, 10:59 PM
skj69nyc skj69nyc is offline
Mein Auto: 535i X drive
I have bought a set. I think they are great for the price.
Old 09-30-2013, 09:44 AM
6ICEMAN9's Avatar
6ICEMAN9 6ICEMAN9 is offline
Mein Auto: 08 550i
They almost seem too bright.
Old 09-30-2013, 03:25 PM
F1.tifosi's Avatar
F1.tifosi F1.tifosi is offline
Send a message via Yahoo to F1.tifosi
Mein Auto: BMW 535i Sport, 08 Accord
ours are 64 Watts
it's a 5w vs 8w per LED
Can you post a pic with direct sunlight hitting
Jet Black | LCSW | DP WT | ZCW | ZPP | ZSP | 261 | 2TB | 322 | 415 | 416 | 609 | 610 | 620 | 677 | 6FL | 6UH |F/R Cameras | Escort 9500ix |
Old 09-30-2013, 03:58 PM
mortal300 mortal300 is offline
Mein Auto: 2008 BMW 535i (E60)
Yeah it feels like 64W is almost too bright at night. In the picture e92 posted, I can't even make out the angel eye... is that just a camera issue or a reality issue?
Old 10-01-2013, 02:48 PM
umnitza's Avatar
umnitza umnitza is offline
www.umnitza.com
Mein Auto: ///M
Hey guys, we're going to have 10 of these Dtecs as a tester.
Is there anyone interested for getting the first 10 units of these that we get at $99?
Old 10-01-2013, 07:33 PM
schpenxel schpenxel is offline
DIY'er
I would have about a month ago
But I already bought another set, from you guys I believe
(yep, http://www.umnitza.com/umnitza-ice-v...wl-p-5863.html these to be exact--I am happy with their brightness so far)
Old 10-02-2013, 10:00 AM
umnitza's Avatar
www.umnitza.com
Mein Auto: ///M
the ICE VXX is very very very bright. These are just something we feel like we'll offer at a reduced price in case anyone wants them.
Use code DTEC100 to get a special pre-order price.
http://www.umnitza.com/dtec-v7-h8-le...tt-p-6464.html
Old 10-02-2013, 04:53 PM
Amyles Amyles is offline
Miles Nerona
Mein Auto: 2007 550I M Package
I'm in for one as a tester.Let me know pls. n ty.
Old 10-02-2013, 07:42 PM
umnitza's Avatar
www.umnitza.com
Mein Auto: ///M
preorders are now available on the site using that code.
