Old 09-19-2013, 01:16 PM
Mo A Mo A is offline
Mein Auto: 2008 BMW 528i
BMW code P2402 what does it mean?
I have a 2008 BMW 528i with 70k miles. I recently got a check engine light, and I went to autozone to read the code, they said " it was a Evap system Leak Detect Pimp." I did some research, but yet I still haven't found an answer. I was wondering what does that really mean, and if I change the dmtl pump will it fix the issue? Also what causes them to go bad? Anything will be helpful!
Thank you!
Old 09-19-2013, 01:46 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
Probably EVAP Purge Solenoid
Old 09-19-2013, 01:47 PM
What exactly is that? and if I replace it will it fix the issue? Where is that part located at?
Old 09-19-2013, 02:45 PM
So is that part different than the dmtl pump, as which I was told by researching that it could be the dmtl pump.
