Old 09-22-2013, 08:10 PM
GeoX750Li's Avatar
GeoX750Li GeoX750Li is offline
Mein Auto: 2010 750Li X-Drive
Jersseven, thanks I just went for a short local trip today, but wow. I had the kids and was in traffic, but the car was so jumpy I had to turn it off. If you are not careful, you feel like you are going to lunge into the car in front of you.
Frankly, I don't know if I even need this, except that the sharper throttle response feels great. Actually, maybe its the BMS with this I don't need .
But this is real, great tip. I would recommend for any car.
Old 09-22-2013, 08:46 PM
rajeek's Avatar
rajeek rajeek is offline
Mein Auto: ///M7
I felt the same way. Until you get used to it, it is down right scary! Just turn it down a bit. There are 21 different settings, so there should be a sweet spot there somewhere. Amazing though eh?
So far, 3 confirmed users and 3 recommendations. 100% so far!
Options: Executive Package, M-Sport, B&O Sound, LED Lighting, Drivers Assist, Active Cruise. No RWS (Rear Wood Shelf).
Mods: BMS n63tu Tune, PedalBox, H&R Sport Springs, RD Sport Front Lip, Rear Roof & Trunk Spoilers, 20" Forgestar F14 Rims, Akebono Ceramic Brakes, 20% Front/15% Rear Tint, Carbon Fiber Wrap, Smoked Taillights, 760 Exhaust Tips, "Golf Tee" mod, Kidney Grills & Front Vents Painted Gloss Black, Brake Calipers Gloss Black w/BMW Logos, B&W Carbon Fiber Roundels.
Old 09-22-2013, 08:52 PM
mr-karim's Avatar
mr-karim mr-karim is offline
bimmerfest coolest Member
Mein Auto: Audi R8 v10 Spyder
Ordering one tomorrow
Audi R8 v10 Spyder - Current
2015 BMW i8 - Retired
Lamborghini Gallardo LP560-4 - Retired
f13 BMW M6 Coupe - Retired
f01 BMW 750xi Dinan Stage 5 - Retired
2011 Mercedes-Benz e350 - Retired
Old 09-22-2013, 08:53 PM
rajeek's Avatar
Mein Auto: ///M7
Originally Posted by mr-karim View Post
Ordering one tomorrow :/
Post your thoughts after install.
Old 09-23-2013, 11:56 AM
mr-karim's Avatar
Just Placed an order, should receive it next monday
Old 09-23-2013, 11:57 AM
mr-karim's Avatar
rajeek
Is it that easy to install? Or should I just bring it to my local dealership? Is there an OFF button on a controller?
Old 09-23-2013, 01:40 PM
rajeek's Avatar
Mein Auto: ///M7
My PedalBox Review
rajeek
You should be able to do yourself. It is literally only 1 harness clip. When you get it, you can plug the pedal box clips into themselves to see how it clips into the car accelerator. I just used some 90 degree alligator pliers to get it out gently. No need for a dealer.
The controller can be turned off if needed via its buttons.
Old 09-23-2013, 02:06 PM
GeoX750Li's Avatar
Definitely do it yourself, Jersseven provided great step-by-step directions:
http://www.bimmerfest.com/forums/sho...9&postcount=29
The only remotely tricky part is disconnecting the cable to the gas pedal. You have to grab both sides of the connector, including the side that you cannot see, and squeeze and pull.
I would also have a torx set on hand to remove the lower dash panel under the steering wheel so you can hide the cable to the remote.
Old 09-23-2013, 09:03 PM
rajeek's Avatar
Mein Auto: ///M7
Good suggestion. May try that soon.
Old 09-24-2013, 02:36 PM
mr-karim's Avatar
rajeek
How is the pedalbox different from BMW's Sport mode?
In pedabox, when you click on sport+ does it suck in crazy amount of gas?
Old 09-24-2013, 02:40 PM
rajeek's Avatar
Mein Auto: ///M7
rajeek
It increases the sensitivity of the accelerator pedal. I haven't noticed any dramatic difference in gas consumption. After you get used to it, you will automatically back off onthe pedal, but when needed the virtually instant power is there when hitting the pedal harder. I guess if your always hitting it hard, you will suck up gas quite a bit more.
Old 09-24-2013, 02:56 PM
mr-karim's Avatar
rajeek
Can't wait to try it. So is it way more sensitive than in BMW's Sport + mode?
How did you like the eco mode? What's you mpg or L/100?
Old 09-24-2013, 04:28 PM
rajeek's Avatar
Mein Auto: ///M7
rajeek
Yes, way more sensitive depending on the setting. Eco is a little soft for me, I prefer normal sport mode on the pedal box. Currently I get about 16-18mpg which has not changed all that much with the pedalbox.
Old 09-24-2013, 04:40 PM
mr-karim's Avatar
Still nice, I get 12-14 mpg, I guess my driving is a little to harsh + damn Dinan air intakes
Old 09-24-2013, 05:09 PM
PREDATOR 007's Avatar
PREDATOR 007 PREDATOR 007 is online now
Mein Auto: 2016 ///M5
Raj! C'mon Man, bring back your old siggy!
** Removed ** 19,000th, 22,000th, 22,222th, 26,000th, 35,000th, 45,000th 48,000th, 63,000th, Honorary 87,000th and 93,000 post in delete pls
WR 12.50 @ 112.05 MPH 9/18/14
Old 09-24-2013, 06:09 PM
rajeek's Avatar
Mein Auto: ///M7
Screw you man, not happening you RWS snob. Well fine...ok then.
Post your Pedalbox thoughts after you have a chance to try it out!
Old 09-24-2013, 06:11 PM
mr-karim's Avatar
I'll even make a video
Old 09-24-2013, 09:39 PM
GeoX750Li's Avatar
Just drove the car for the second time with PedalBox, set to Eco this time and it felt pretty good. Only a local trip to Portillo's with kids in car, but Eco surprised me with a hard step-off. A little throttle launches pretty hard, with no lag, felt extremely responsive. Power does drop off above 2500 RPM, but the responsive throttle is great for around town.
I wonder how Eco really works, what it does to the car to make it so initially responsive?
I can't wait to get it out on an open road or highway to see if throttle lag really is eliminated. This thing is a lot of fun.
Old 09-24-2013, 10:42 PM
rajeek's Avatar
Mein Auto: ///M7
It is fun eh? As long as you are over about 2500RPM as you noted, lag is virtually gone. Even if you are below that, you will still have much less lag, because as soon as you start to hit the 2000's the car starts to kick of like a rocket vs still having a bit of delay w/o the box!
Old 09-25-2013, 04:18 AM
I ordered mine last Friday and just received an email yesterday that it is going to ship Thursday. Was hoping to have it sooner, but oh well. I'll post a review once I have it installed.
Thanks for bringing the girls back Raj!
Old 09-25-2013, 07:45 AM
mr-karim's Avatar
Hello,
I just wanted to inform you that your order will ship on Thursday sept 26.
Best Regards,
MotiveMods
2691 E Hacienda Ave
Las Vegas, NV 89120
Same, they were out of stock as far as I know.
Old 09-25-2013, 08:53 AM
rajeek's Avatar
Mein Auto: ///M7
My PedalBox Review
Mine shipped same day. I guess you guys bought up all his stock!
Old 09-27-2013, 12:06 PM
goren123's Avatar
goren123 goren123 is offline
Mein Auto: 2011 BMW 750Li xD
My PedalBox Review
I got the same email.....will ship 09/26....
Old 09-30-2013, 07:23 AM
goren123's Avatar
My PedalBox Review
Received my pedal box last Saturday. I have not installed it yet. Do you guys find a nice location to hide the controller? I have to hide it from my wife. Yet it should be easily accessible to play around with it.
My second question:
Do I need to uninstall it every time I take the car to the BMW service? same question is true for BMS S1 too.
Old 09-30-2013, 09:21 AM
rajeek's Avatar
Mein Auto: ///M7
My PedalBox Review
My second question:
You can hide it between the seat and the front console. If your just going on for simple routine maintenance just hid it under the mat or something and set it to off. They will never look if it is just routine maintenance stuff.
-*nga*-
