Old 10-02-2013, 04:01 PM
PREDATOR 007's Avatar
PREDATOR 007 PREDATOR 007 is offline
Mein Auto: 2016 ///M5
Originally Posted by mr-karim View Post
Richard109
$150/hr, they took $80 for 40mins. But they actually removed the panel in order to hide those wires, the job is done well
I think you got robbed. Everyone has to make money, but they have to consider something as minor as this as "good will". Do you suppose that they know that you may be shopping for a new car next year? Wouldn't it be nice if you remembered how well they took care of you? My dealer is the same as yours unfortunately.
I own a couple of Toyota's and the service department has helped me out on several occasions for no charge.
** Removed ** 19,000th, 22,000th, 22,222th, 26,000th, 35,000th, 45,000th 48,000th, 63,000th, Honorary 87,000th and 93,000 post in delete pls
WR 12.50 @ 112.05 MPH 9/18/14
mr-karim's Avatar
mr-karim mr-karim is offline
bimmerfest coolest Member
Mein Auto: Audi R8 v10 Spyder
You guys have a 2013 top of the line BMWs, why not spend $80 instead of installing it by youself?
Audi R8 v10 Spyder - Current
2015 BMW i8 - Retired
Lamborghini Gallardo LP560-4 - Retired
f13 BMW M6 Coupe - Retired
f01 BMW 750xi Dinan Stage 5 - Retired
2011 Mercedes-Benz e350 - Retired
Old 10-02-2013, 04:02 PM
Originally Posted by rajeek View Post
That is probably about right. Here's my break down minute by minute:
1. 2 min to remove current accelerator pedal
2. 7 min to remove panel
3. 2 min to install pedal box
4. 7 min to re-install panel
5. 3 min to re-install accelerator pedal
6. 19 min to spank monkey after seeing Mr. Karim's soft and supple hands.
Job done. 40 min.
I'm about to pull out my RWS and beat you with it.
Old 10-02-2013, 04:04 PM
I like the satisfaction of doing some things myself. I even pump my own gas.
Old 10-02-2013, 04:14 PM
mr-karim's Avatar
Richard109
I don't mind pumping my own gas, but when doing something major, I like the satisfaction when something is done professionally. My occupation is based on computer science, I can do something computer related but for example, if I break my hand, I won't try to fix it by myself, I'd go to the doctor, because the doctor would know better
Old 10-02-2013, 04:48 PM
Snorlax Snorlax is offline
Mein Auto: _
My PedalBox Review
Promise to tie me up and ball gag me first?
Old 10-02-2013, 07:03 PM
goren123's Avatar
goren123 goren123 is online now
Mein Auto: 2011 BMW 750Li xD
My PedalBox Review
I removed the the pedal. It was easy. However I could not disconnect the cable. I pull it, tag it.... No result. Would you please tell me how to do this? Do I need to pry it to disconnect?
I usually destroy things very easily I do not want to damage the cables/pins. I second Mr. Karim's solution; money well spent IMO.
Old 10-02-2013, 07:09 PM
goren123's Avatar
My PedalBox Review
No comment
Old 10-02-2013, 07:10 PM
mr-karim's Avatar
goren123
Only $80 and problem solved You won't see a single wire hanging
Old 10-02-2013, 07:40 PM
Doktorek's Avatar
Doktorek Doktorek is offline
Mein Auto: 750 Li
How does Pedal Box mod compare to N63 Stage 1 from Berger performance? What I mean, which one will give you better performance response? Would doing both be 2x beneficial? Would anybody recommend it? http://www.burgertuning.com/N63_Jb_B...nce_Tuner.html
2008 BMW 750 LI
2010 Panamera Turbo
Old 10-02-2013, 07:42 PM
mr-karim's Avatar
Doktorek
You gotta have both, for the best performance
Old 10-02-2013, 07:43 PM
GeoX750Li's Avatar
GeoX750Li GeoX750Li is offline
Mein Auto: 2010 750Li X-Drive
You need to squeeze the connector on both sides while you pull, one side you can see the tab and squeeze the corresponding area on the other side.
Old 10-02-2013, 07:47 PM
goren123's Avatar
My PedalBox Review
Thank you!
Old 10-02-2013, 08:10 PM
Mein Auto: _
My PedalBox Review
Doktorek
+1. With both the BMW beast is released
Old 10-02-2013, 10:14 PM
Mein Auto: _
Come on. Someone help me out.
Old 10-03-2013, 03:07 PM
mr-karim's Avatar
Old 10-03-2013, 07:56 PM
mr-karim's Avatar
Did anyone try to combine the BMW's Sport + mode, with a DS mode and a Sport+ PedalBox mode?
Old 10-03-2013, 09:00 PM
badblack550xi's Avatar
badblack550xi badblack550xi is offline
Chilling
Mein Auto: F10 2013 550i xdrive
that air freshen is the freshest mod you have =D
2013 F10 550ixdrive Carbon black metalic / BMS Stage 2 / AR Down Pipes/ 3" Custom Exhaust/ M5 mufflers and diffuser. WR 11.895 @118.69
Old 10-05-2013, 09:45 AM
mr-karim's Avatar
I did 0-100 pedalbox test for you guys Check my topic http://www.bimmerfest.com/forums/sho....php?p=7878626
Old 10-06-2013, 11:48 AM
goren123's Avatar
My PedalBox Review
After couple of hours of pedal box experience, I agree with Raj. This is great.
My Kia responses like S5 during take offs. It does not power down itself when the engine is turned off would be the only criticism I would raise. I am expecting to see increase in oil consumption more than gas. Click image for larger version
ID:	400778Click image for larger version
Old 10-06-2013, 12:32 PM
mr-karim's Avatar
rajeek
Old 10-06-2013, 12:41 PM
lol, now that's funny!
Old 10-06-2013, 12:49 PM
Mein Auto: _
Ha. You got me! Good one.
You are more right than you know. Sadly I don't even have my Kia now that it is being fixed after being rear ended.
http://www.bimmerfest.com/forums/sho...d.php?t=726232
Old 10-09-2013, 10:29 PM
Mein Auto: _
Just a bump.
Lets get some more reviews up there!
Old 10-09-2013, 11:41 PM
goren123's Avatar
My PedalBox Review
I think pedal box Eco mode helps mpg a little.
-*nga*-
