Old 09-21-2013, 03:33 AM
RBeattie RBeattie is offline
Mein Auto: 320d
BMW E90 320d estate unknown warning messages
This is my first post but I have trawled manuals etc for several hrs. Last night a warning came up on the car when stopping the engine which is neither online or in the manual. The symbol is an amber circular arrow and exclamation mark with a capital A in the middle. There is no mention of the error message in the manual, online, I the 3 series handbook or X5 handbook which I cross referenced just in case.
Has anyone else experienced this. At the same time the red oil service light came on going from 14000 - 0 on restart. I have a suspicion it is a sensor issue or the ECU has gone haywire. Check with garage on service record and all sound - all other message remain good. Did a check on the dashboard and all ok. A very bizarre issue.
Suggestions would be welcome what the A symbol is.
Old 09-21-2013, 03:47 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Are you sure it's an "A" and not a triangle with an exclamation point?
Because if it's this the DSC/DTC system is complaining.
The second light on an unrelated system is odd. A post by DSXmachina in another thread stated that the ABS/DSC system is a high current draw system, and suggested that battery / alternator issues can often trigger the same set of lights one sees in a steering sensor failure. An uninformed blind speculative guess might be to look at the battery / charging system.
Old 09-21-2013, 04:11 AM
Mein Auto: 320d
Afraid not - The symbol is absolutely a letter A -
Sat there and checked a dozen times.
It is bizarre
Old 09-21-2013, 04:18 AM
Mein Auto: 320d
Thanks for the suggestion - I was wondering if the A stood for Alternator - I do tend to agree that it could be a battery related issue.
The car is really well maintained and all the mileage is motorway so am suspecting a battery is approaching end of life as when I left the key fob a yellow battery warning appeared on a couple of occasions. this would also explain the rogue reset on the service counter as well. Time reset itself last week so all points to that core issue, a secondary sign of a battery issue.
The perplexing issue is the symbol
Old 09-21-2013, 04:27 AM
Mein Auto: 320d
Just had a phone call from the garage and the symbol is a warning on the traction control of the E90 - could be a sensor gone. Very odd as it isn't in the manual. Lucky it isn't winter.
Old 09-21-2013, 05:30 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Post a pic for us....
e90 warning message
