Old 09-22-2013, 12:11 AM
BROOKSBC's Avatar
BROOKSBC BROOKSBC is offline
Mein Auto: 01 BMW 330i
Brake and oil light reset
How do I reset the oil service light after changing my oil and the brake pads inspection light. This is on my 07 328i.
Old 09-22-2013, 03:32 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
The brake service light is triggered by both mileage and a physical wear sensor in the pads, so the pad sensor needs to be replaced as part of the brake job.
Old 09-22-2013, 04:34 AM
Banned
Mein Auto: 2007-335 HTC
if you replace the pads before the sensor is worn thru, you only need replace the pads, Catch them early and you can save 60 bucks on sensors
Old 09-25-2013, 10:58 AM
BROOKSBC's Avatar
Re: Brake and oil light reset
Ok I got that part fixed but how about the oil light after changing the oil. The service requirements light and oil light are still on. An oil can and the car up on a hoist.
Old 09-25-2013, 11:09 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Most maintenance questions can be answered HERE
Old 09-25-2013, 01:36 PM
Zooks527's Avatar
The oil light resets the same way as the brake light, using the method in the video.
Once you're in the reset menu, use the switch on the face of the turn signal to scroll to the oil service light and then perform the reset.
