Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 09-22-2013, 07:29 AM
Jon Phillips Jon Phillips is offline
Jon Boy
Mein Auto: 1985 528e
New altranator not charging
I have installed two new alternators in my '85 e-28. Thinking the first one was a dud. I put the second one in, still not charging. I've checked all fuses, ground connections, the battery is new. What am I missing here? Is there a bad relay switch causing this problem?
Thanks in advance for any help with this issue.
Old 09-23-2013, 06:31 AM
Brobby87's Avatar
Brobby87 Brobby87 is offline
The Arch Bishop
Mein Auto: 2003 325i, 1986 535i
Could be caused by a burned out bulb that illuminates the red battery light in your dash cluster. Start there. Is the light coming on when you turn the key to accessory?
Old 09-23-2013, 12:47 PM
catso's Avatar
catso catso is offline
catso
The electrical connections to the alternator and battery would be the first things I would check. Sometimes wires and connections corrode under the insulation, where it's not visible. Corrosion and electrical problems are common with these older cars and very often difficult to detect.
![/I][/FONT]
Old 09-23-2013, 08:27 PM
BMWFatherFigure's Avatar
Old School
^^^ +1... Check really carefully. Even to the point of removing and remaking connections.
Current:
E38 Parts Car
Previous:
HTML code is Off
