Old 09-23-2013, 02:36 PM
Panfili Panfili is offline
Mein Auto: 2010 328XI
Broken rubber seals around door opening
I drive a 2010 328Xi and the rubber seal around the driver and passenger door openings are ripped. Has this ever happening to anybody and is it normal for a BMW? The seal seem to be very soft and even the slightest pant rubbing went entering the car would damage it. BMW Laval said it wasn't covered!!! BMW Canada said the same... Any thoughts?
Old 09-23-2013, 03:47 PM
Slvr335 Slvr335 is offline
Mein Auto: 2008 Stage II 335i
The ones in my 2008 are like that.
It's caused from 'sliding' in and rubbing them...
Old 09-23-2013, 04:16 PM
pspressart pspressart is offline
Mein Auto: 2011 335i coupe
I had a 2002 325xi sedan and I replaced the rubber seal on the driver's door three times and the fourth was almost worn out when I traded it in after 11 1/2 years of ownership.
Old 09-23-2013, 05:43 PM
pmacd55's Avatar
pmacd55 pmacd55 is offline
Mein Auto: whatever the Mrs doesn't
2011 328x - replaced drivers side rubber twice under warranty and was crumbling a 3rd time when I traded it this summer. I will say the SA acted like they had never seen it before but never questioned replacing it.
2016 F23 M235xi Ragtop Mineral Gray/Oyster <- Love this car !
2016 F48 X1 Alpine White/Canberra Beige
2013 E93 328i Cabrio DSB/Oyster ED (July 2013) - retired
2013 F25 X3 MSport Space Gray/Oyster PCD - retired
2011 E90 3281 Sedan Space Gray - retired
2009 E83 X3 Platinum Bronze - retired
Old 09-23-2013, 06:06 PM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
Spilled Coke is often a culprit .... you could move to the US an get this covered under warranty .... wouldn't be a s bad as moving to Ontario ......
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 09-23-2013, 06:36 PM
fun2drive's Avatar
BMWCCA 149159
I have an M3/4 BMW and my E93 and none of these rubber seals sees wear because I don't get in and rub the seals, I turn 90 degrees and sit in the car then pivot to be facing the steering wheel. It doesn't wear the seat and has worked well. I did see wear on my other cars on the seal and also the vinyl protective strip that you also rub getting in and out. This isn't unique to BMW it happens with all cars that you have to wear to get in and out of...
