Injen SP N55 Intake. Anyone Tried or Seen This? - Bimmerfest - BMW Forums
Old 09-23-2013, 10:45 PM
WhiteFury's Avatar
WhiteFury WhiteFury is offline
Booooost!
Mein Auto: 2011 335i N55
I was thinking about burger motorsports intake, then I came across this intake. Has anyone use this? I am wondering if its worth double the price tag of burger motorsports intake.
http://www.europeanautosource.com/pr...m-n55-variants
JB4 Stage 2 | Injen CAI | BMW PE | AR Catless DP | Alpina TCU Flash | Eibach Pro Kit | Custom TCKline Koni's | 19" RS7 Wheels | DWS Tires
Old 09-24-2013, 05:25 AM
TheyCallMeNun's Avatar
TheyCallMeNun TheyCallMeNun is offline
Fest Wrks
Mein Auto: 07 335i coupe
cold air intakes are pretty much all the same. I could make one with PVC pipe, clamps and dryer sheets. Only minor differences between products, nothing important either. So I would suggest not spending much money on it at all. The one your looking at doesn't look like it belongs to these engines. The pipe is extended too far.. Where would it go? but I have N54 so it might be different.
To sum it up..
It's close to triple the price, go for BMS!
Edit: I saw the picture of it installed... looks like too much work
BMW Owner Since 17
'00 323i
'07 335i coupe
Black Sapphire 6MT
BMS JB+ & DCI
Turbosmart BOV
Old 09-24-2013, 05:42 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Do your homework WF - stock's fine. Unless performance is less important than sound/appearance or you plan much track time. Little if any street benefit.
Old 09-24-2013, 11:31 AM
Mein Auto: '06 AW 330xi
+1 to what Calwaterboy said.
Aftermarket intakes do 2 things...
1) Make noise
2) Increase throttle response.
The latter is a benefit from a higher flowing filter element. A drop in filter such as those made by K&N or aFe, will give you the better throttle response that aftermarket intakes provide without the excessive added noise.
If you want the noise, it's your call. I personally think they are a waste of money.
The OEM design is as efficient as it gets. On my car, I cut out the carbon filter, removed the air silencer on the intake boot, and dropped in a aFe oiled filter.
Old 09-24-2013, 11:43 AM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is online now
2018 440M-Sport MPPSK/THP
Mein Auto: 2018 440M-Sport/MPPSK/THP
Stock intake cars have run 11.9/118mph I expect you don't really need one except for the noise.
Kevin
CURRENT:
2018 BMW 440M-Sport MPPSK/THP 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
477 WHP of BURBBLES
HOME FROM PAINT
Old 09-24-2013, 05:01 PM
WhiteFury's Avatar
Booooost!
1) Make noise
Where is the air silencer on my car. I cant find it. I have the intake box and filter but no other filter and I dont know where the silencer is on a N55
Old 09-24-2013, 06:12 PM
TXFred TXFred is offline
Mein Auto: 2008 335i Convertible
The intake, filter and assorted ductwork are the silencer.
On a sidenote, can somebody please explain to me why aftermarket intakes like the one we're discussing are called cold air intakes.
My OEM intake sucks cold air from the kidney grills in front of the radiator. Every "cold air intake" I've seen is set up to inhale scalding hot air from behind the radiator.
Frederic
Any idiot can be fast in a straight line. The corners are what separates the drivers from the commuters.
Old 09-24-2013, 08:03 PM
They are not CAI's - Cold Air Intakes. Proper term for the Burger Motor Sport unit is DCI - Dual Cone Intakes
Kevin
CURRENT:
477 WHP of BURBBLES
HOME FROM PAINT
