E36 (1991 - 1999)
Old 09-24-2013, 12:49 PM
E36blownpast E36blownpast is offline
Mein Auto: E36 325i
Exclamation differentials
hey so i just finishing up a 302 5.0 swap into my 92 325i and i was wondering what differential i should use. its a daily driver and weekend drift car. i was lookin into the 3.91 but figured id ask since you guys probobly know more about the facts while im only good at installing and making stuff work. lol so let the suggestions begin...also axels? let me know what i need!!
Old 09-24-2013, 12:59 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
The diff ratio is dependent on your transmission ratios, so you'll have to provide that information. As far as axles go, you'll want to use 328/M3 axles for their additional strength.
1998 BMW 328is
1966 Pontiac GTO
Old 09-24-2013, 05:02 PM
Mein Auto: E36 325i
T56
1st gear : 3.36:1
2nd gear: 2.07:1
3rd gear: 1.35:1
4th gear: 1.00.1
5th gear:0.80:1
6th gear: 3.28:1
Old 09-24-2013, 06:30 PM
Jakobie1086's Avatar
Jakobie1086 Jakobie1086 is offline
Just a kid with a toolbox
Mein Auto: 330ti
Originally Posted by E36blownpast View Post
T56
1st gear : 3.36:1
2nd gear: 2.07:1
3rd gear: 1.35:1
4th gear: 1.00.1
5th gear:0.80:1
6th gear: 3.28:1
....6th gear is almost the same as first? That's strange
Old 09-24-2013, 06:40 PM
Mein Auto: E36 325i
Yea i thought that too leme see if i go.that right
Old 09-24-2013, 06:43 PM
Mein Auto: E36 325i
correction
BA1 Ford 5.0 / 5.8 500 ft/pd torque- gears=
1st 2.97
2nd 2.07
3rd 1.43
4th 1.00
5th .80
6th .62
Old 09-24-2013, 07:22 PM
southpark11235's Avatar
southpark11235 southpark11235 is offline
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
nope thats right
No it is incorrect. What you are marking as 6th gear is actually reverse. Assuming the other info you gave is correct, here are your transmission's gear ratios:
1st 3.36:1
2nd 2.07:1
3rd 1.35:1
4th 1.00:1
5th 0.80:1
6th 0.62:1
reverse 3.28:1
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 09-24-2013, 08:14 PM
Mein Auto: E36 325i
ok but now what differential do i wana go with?
Old 09-24-2013, 08:28 PM
SPapaJr's Avatar
SPapaJr SPapaJr is offline
VP Moon-Based Operations
Mein Auto: 1998 323is
How much of a "daily driver" is it? As in, will you be using the interstate a lot?
With a 3.91 I believe you'll be doing 5000 rpm at 65 mph...
Old 09-24-2013, 09:49 PM
ZeGerman's Avatar
Warm Leatherette
You can use this calculator to determine your RPMs:
http://www.powerblocktv.com/resources/
1998 BMW 328is
1966 Pontiac GTO
Old 09-24-2013, 10:37 PM
SPapaJr's Avatar
That's pretty nifty. Thanks, ZeGerman.
Old 09-25-2013, 08:10 AM
ZeGerman's Avatar
Warm Leatherette
Sure thing. And if you want help determining the outside diameter of any given tire size (which is needed when using the gear ratio calculator), you can use this tire size calculator:
http://www.miata.net/garage/tirecalc.html
This one is nice to have around when shopping for tires, since it lets you see the differences between two different sizes.
1998 BMW 328is
1966 Pontiac GTO
Old 09-25-2013, 10:16 AM
Mein Auto: E36 325i
wait now im confused...how do i use this lol sorry like i said im prety much a noob when it comes to information...i just know how to put it together and make it run :/
Old 09-25-2013, 10:55 AM
ZeGerman's Avatar
Warm Leatherette
Well, in order to use the gear ratio/RPM calculator, you need to enter the outside diameter of your tires, so you'll have to source that information from somewhere. The tire size calculator I posted provides you with the ability to enter your tire specs (205/60, 215/50, etc...) and obtain the outside tire diameter in inches. Take that figure and plug it into the gear ratio/RPM calculator.
1998 BMW 328is
1966 Pontiac GTO
Old 09-25-2013, 11:22 AM
Mein Auto: E36 325i
ok does this sound right?
speed i did 120mph (normal top speed in my opinion)
tire diameter is 23.1 inch
axel gear ratio 3.91
and i used 6th gears ratio which is .62
and i wasent sure what to use for transfer case ratio so i did 1.00
my final rpm was at 4233.03
is that correct? lol like i said i dont relly understand how to do this but if its correct than i should be able to use the 3.91 without any problem but i have a feeling im wrong lol
Old 09-25-2013, 11:56 AM
ZeGerman's Avatar
Warm Leatherette
What size tires are you using that have a 23.1" outside diameter? A stock tire for the 325 non-sport has an outside diameter of 24.7". A tire with an outside diameter of 23.1" would be very small, and your speedometer would be wildly inaccurate.
Also, I would base your differential gear ratio decision on the highway speed limit in your area, not a theoretical top speed (which 120mph is far too low anyway). This way, you will know what your highway cruising RPM will be, which is far more applicable to real-world conditions than top speed (unless you're building a car specifically for Bonneville Speed Week or the Texas Mile, which I doubt...).
So... Say you are running stock tires, which have an outside diameter of 24.7", your diff is a 3.91:1, and your 6th gear is a 0.62:1 overdrive. At a speed of 65mph, which I believe is your state's typical maximum highway speed limit, your engine will be spinning at 2144.37rpm.
1998 BMW 328is
1966 Pontiac GTO
Old 09-26-2013, 07:53 AM
Mein Auto: E36 325i
so is that a desirable rpm to be at when going 65mph, because thats about what my jetta sits at on the freeway at 65...or do i want that 6th gear to be longer?
also what are the differential options for the e36's....with lsd
Old 09-26-2013, 09:54 AM
dc_wright's Avatar
dc_wright dc_wright is offline
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
The 3.91 is really your best choice. If you go to the 3.38 you're going to be almost bogging the engine at highway cruising speeds. The only diff with a higher ratio is the 4.04 from the 318 and I believe that is a physically smaller diff which likely isn't a good choice to be mated up with a 5.0 liter powered vehicle.
http://www.bokchoys.com/differential/GearRatios.htm
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 09-26-2013, 10:14 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
hey so i just finishing up a 302 5.0 swap into my 92 325i..let me know what i need!!
It seems like you need your head adjusted for putting a 5.sl0w motor into a BMW.
Why?
i was wondering what differential i should use..?
You're a drifter...
but, you cant be bothered to learn about what you're building.. (?)
Were you trying to EDUCATE yourself?
or just wanting a answer to your query "what differential should I use?"
Ze German gave you some great places to start.. but it seems you dont know where to begin...
Your Mustang with V8 came with 2.73 - 3.73 in the diff..
BMW's with V8 use 2.93 - 3.64 in the diff..
If you have the money.. you can pick whatever ratio you want.
(dont drifters just weld the rearend anyway?? )
If you want to make this easy..
FIND A COMPLETE BMW REAR SUBFRAME ASSY with 3.23 LSD.. (I got one if you need it)
You get the M brakes, M axles, M Diff (with LSD)
re-inforce your mounting points on your "drift" car since it IS NOT A M from the factory.
When you got the whole ass end apart for the subframe swap,
RE-inforce the mounting points for the sub-frame, and your rear Shock towers!
Unless you want the shock to blow through the wheel well in the trunk and cause you more work.
YES, it DOES HAPPEN!
You are aware of the weak spots on the standard E36 chassis, right?
Brace the hell out of your e36 if your seriously planning on Drifting it..
especially after your swap.. get the suspension dialed.
Anytime you make a adjustment... even a small one.. you have to re-check EVERYTHING.
Cheers!
EDIT:
Here is some light reading.. Enjoy..
http://forums.bimmerforums.com/forum...?t-853341.html
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 09-26-2013, 10:21 AM
dc_wright's Avatar
Aw man, now you've gone and given the recipe for the secret sauce away! I was looking forward to the future posts titled "I Ripped The Entire Rear Subframe Out of My E36" (photos included)
Old 09-26-2013, 10:25 AM
Mein Auto: BMW
^ +1
Me too!
I want to hear about the joys of "daily" driving a v8 with a 3.91..
Old 09-26-2013, 10:45 AM
dc_wright's Avatar
Since he did it right and swapped in the tranny too, it should do OK as a DD. If he'd used an adapter kit and mated it up to the OEM tranny which has shorter and closer gear ratios, not so much fun, particularly with that 3.91.........
I had a friend that had an older Chevelle that was set up for the 1/4 mile and was also his daily driver. The 5.13 rear diff made it awesome on the track but it just wore you out driving it on the street with the continuous shifting required.
Old 09-26-2013, 10:49 AM
Why?
I believe it is you need your head adjusted. American car manufacturers have always been good at one thing, and that’s POWER. Why wouldn’t you want to take a firebreathing V8 and put it in a car that can actually take a corner well? It is the perfect combination, taking the best aspects from both cars to create a monster in the straight and the corners.
OP, just like in your last swap thread, I approve this swap.
Old 09-26-2013, 11:10 AM
Mein Auto: BMW
Originally Posted by southpark11235 View Post
I believe it is you need your head adjusted. American car manufacturers have always been good at one thing, and that's POWER.
Yes... Ammuuurricakkannannns have been putting big motors in small cars for damn near a century.
Its a pretty simple concept.. one simple people cant get out of.
The "illusion" of "POWER" as you put it... is a seductive b!tch
Why wouldn't you want to take a firebreathing V8 and put it in a car that can actually take a corner well? It is the perfect combination, taking the best aspects from both cars to create a monster in the straight and the corners.
Yes, these E36's handle GREAT.
But, when you shoehorn a V8 into a E36 you unsettle the vehicle.
The NOSE of the car is now HEAVIER than before..
which compromises that great HANDLING we both have grown to love.
Not exactly a "perfect" combination, or the "best of both worlds"..
"firebreathing"
.. Its a solid engine for predictable linear power output.
You may have something cute for the straight lines.. but the corners will kill.
(read: physics)
Why even V8? Why no boost? Hell.... WHY NO WERK on MOTOR?
FORM & FUNCTION.. not just cutesy coon-tail builds.
PS-- have amber corner lights.. want?
Old 09-26-2013, 11:30 AM
"firebreathing"
(read: physics)
302 = 460 lbs
m52 = 436 lbs
302 with aluminum heads = 416 lbs
If you use aluminium heads you are actually losing weight, which nullifies your whole handling argument.
325i, differentail, mods, swaps
