Old 09-26-2013, 07:00 AM
wethead4 wethead4 is offline
Mein Auto: e90
Door Sill Clip (passenger side)
hello, the door sill molding has come off and i cant attach it to the clips. Here is a pic of what i'm talking about that i found on another forum. but this is for the e90 so the clip looks slightly different. Anyone know of a good way of reattaching? also anyone know what the part number is in case i've damaged the clip?
Old 09-26-2013, 07:15 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Try bending slightly from the outer edges, but just slightly, and push down on the clip, the other clips slide, but the last one is a PITA.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 09-26-2013, 08:00 AM
Mein Auto: e90
understood, was trying that last night. it seems you cant just slide all of them from right to left or left to right. So you are saying to slide 3 of the 4 in, and then bend the outter edge slightly to slide the last one in from the other way?
I saw a post were someone recommended to pullout the clips with pliers, put them on the molding, and then just manually push the molding in until the clips fastened. I think this was on a e46 though, is this not recommended?
Old 09-26-2013, 08:34 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Still works the same way. You'll drive yourself to distraction trying to reattach the trim to the clips if it has dislodged leaving the clips in the body. Pull them all, reattach to the trim panel, set the trim in position, align all clips with their holes (that's why they slide) and give a firm whack to each with the side of your fist to set them in place.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 09-26-2013, 08:46 AM
Mein Auto: e90
THanks, will give a try and report back.
Old 09-26-2013, 09:18 AM
thekurgan's Avatar
Bad Lieutenant
Yes, make the piece "bow" a bit, and when you feel the clip is attached underneath, release the "bow". If you hit these things too hard, they will split.
Ilse
Bruna
BMWCCA #453648
Old 09-26-2013, 10:16 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
Pull the pins put them in the strip and press down.
Pull the strip out.(just pull vertically from the inside edge.Its pretty hard to hurt it)
Pull the pins out with a tool of your choice put them in the strip and press down.
That is the solution to this puzzle . I ran into the same thing
installing speakers under the seats. If you should happen to break one
of the pins they are cheap like a dollar .
I used one of those plastic pry bars to pull them.
pictures and part number included in the following link
see page 28 and 29
http://www.e90post.com/forums/attach...3&d=1329017429
BMW part no.
51-47-7-117-532 b18d clip wi .91 each door sill fastner
