Old 09-26-2013, 09:31 PM
venky5000 venky5000 is offline
Mein Auto: 328I
Stock stereo not working when i switch on the headlights
Freaky electrical issue in E90/07 base model 70,000 miles. 6 years warranty is up and need to figure out a solution. The problem is when I turn on my headlights the stock stereo doesn’t work even the display doesn’t come up. This happens when the engine is on. Stereo works perfect when in the day time and also when the engine is not running.
Took it to a Local BMW service guys at charlotte, “Dynamic Auto Tune (DAT)”, who is specialized in this, but still not able to figure out the issue. Last update from DAT was, took all the data and sent for reviewal in England.
Any suggestions ?
Venky
Old 09-26-2013, 10:15 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
Most likely a low battery.
If the battery is low the IBS system can turn non essential stuff off.
Read about ibs in the link below.
http://www.bawarec.ru/manuals/3er/e9...3er-e90-12.pdf
That's the first thing to check. Get out the voltmeter.
Try giving the battery a slow charge to see if the problem goes away.
6 years is usually as much as you get from a battery in this model.
And when they go bad strange stuff happens this is usually is accompanied
by long cranks. On a new a battery the car will start almost instantly.
There also could be something faulty with the IBS.
Normally the IBS only turns stuff off when the engine is not
running.
There was also that power cable recall for the main fuse box in the cabin did
you have that done or was it necessary for you year and month build. I would
check that also.
Old 09-27-2013, 05:38 AM
Banned
Mein Auto: 2007-335 HTC
well if you take it to Hendrix BMW on Independance, you best do a walk around your car before you leave, they have chipped the paint on my car twice, and I have only taken it there twice,
Old 09-27-2013, 10:13 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
Don't quite know how these radios are wired... On my previous car, issues with the wire that came into the head unit to dim the screen and turn on the button backlighting would sometimes cause the radio to turn off. Could be something similar?
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 10-10-2013, 07:58 PM
Mein Auto: 328I
Any suggestions ?
Venky
The problem still persists, the data had been collected couple of times and sent to England. Paid $600 for gasket leak and tensioner replaced.
But I just recollect what I did 3 weeks back to my car, I had increased the lighting of the interior dashboard, accidentally remembered it and reduced it to 3 points, stereo is working now… Temporally issue resolved. Will keep you posted and thanks for all your advise.
Venky
Old 10-11-2013, 09:58 AM
bocabimmer's Avatar
If that's working, I'd suggest not messing with it. It's much cheaper than having someone stabbing around trying to diagnose it.
2014 i3 BEV
Old 10-11-2013, 03:38 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Yes! Very wise. Anyone who has a history with British cars knows how very well they deal with electrical issues.
Clearly this is a capacitor problem - simply put, your supply of electrons is insufficient to run both the headlamps and the stereo when the engine is drawing electrical load. BMW preferentially supplies the headlamps & engine as a safety measure.
9 times out of 10 it is the Flux Capacitor. That's a special design component - the guys at DAT may not have the expertise to fix it. Recommend you contact your BMW dealer asking for a resolution - I believe dealers carry an inventory of Flux Capacitors.
