Failed smog!!! - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 09-27-2013, 12:50 PM
vmaxman vmaxman is offline
Mein Auto: 95 325i
Angry Failed smog!!!
I just cant drive this car without spending more money!! so heres the deal my car failed smog bad!!
Iive just rebuilt the whole top end... replaced my cam sensor, crank sensor , o2 sensor, both knock sensors, airfilter, oil, coolant, new vanos and sparkplugs are only 6 months old.... whats the deal?? only upgrade to my motor is M3 cams... and i have a catback exhaust system
I just replaced my DME with a red label two days ago cause my silver label fried and ive only driven about 50miles with the new computer.... could that make a difference?? My cats are only about 2yrs old and my car passed with flying colors last time i smogged it.. what could possibly be bad??
side note... my car seems to have more power when its cold, after its warmed up first gear feels extremely sluggish(i could pull out in 2nd gear and it feels the same as first) and it doesnt seem to pull until after 4krpms(it ran like this before the M3 cams too)
Jason
1995 325i SOLD
Black 18" Hamman wheels
umnitza exhaust
M3 bumper
Old 09-27-2013, 12:54 PM
Mein Auto: 95 325i
these are my smog numbers... would new cats change it that much?? i dont wanna spend $300 on new cats if they wont bring my numbers down that much....
1995 325i SOLD
umnitza exhaust
M3 bumper
Old 09-27-2013, 03:41 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
well, hc indicates a misfire (not running rich....that's co)
to have high hc and high nox with little to no free o2 and 'meh' co2 (kinda low-ish...) is quite a feat.
first things first.
how many miles since your top end rebuild??
oe cats or aftermarket?? direct fit or welded in 'universal' if aftermarket??
if your car ran like poop when warm with the oe cams, it will not run much better with the //M3 cams....
sounds like this could be the actual source of your problem, but i cannot confirm that from here.
engine vacuum??
the 'fired' dme gives me pause as well, since these things don't generally do this on their own, something causes it....and you're not in the water intrusion prone years for that to be of a priary cause.
simple things first, like make sure that you have the proper grade fuel in this thing, and your injectors are not flwing poorly. that could cause a lean misfire and potential high nox and *maybe* be the cause of the warm running issue.
when warmed up, the dme runs in closed loop, meaning the dme takes full control over the fuel trim and not factory presets.
make certain the cooling system is not restricted as well, and that the chassis to engine block grounding is solid.
df
Old 09-27-2013, 03:56 PM
Mein Auto: 95 325i
first things first.
engine vacuum??
df
Ive only put about 60 miles on the rebuild(i had to do my top end again... long story)
the cats are a single unit aftermarket weld in(the muffler shop that did it did a cruddy job imo) it looks restrictive and no smooth bends, plus the exhaust pipe used on the cats seems to small...
Well i would say the car runs bad.. just first gear feels dead.. considering its the lowest i shouldnt have so much lag.. maybe its cause of my gearing and my 18in rims??
I always run premium fuel and even had an octane booster in my tank(never had a problem smogging cars before with the booster in it)
also banging on the cat reveals some light rattling... and i just checked the out put of exhaust pressure from my car at idle and it feels kinda weak
Jason
1995 325i SOLD
umnitza exhaust
M3 bumper
Old 09-27-2013, 05:49 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Since you replaced the DME you may not have driven enough miles or through enough run cycles for all of the sensor settings to have settled in. Dino had a similar issue on his car and he found that there's a specific driving cycle you can do to reduce the amount of time it takes to get everything dialed in.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 09-27-2013, 06:23 PM
Mein Auto: 95 325i
Re: Failed smog!!!
Well I ordered new cats, I was checking out my buddies 93 bmw and with his stock exhaust system he had 3 times the exhaust flow coming out of his tail pipe at idle than I did, so I know my cats are clogged. but I believe your right, I needed more miles on the car for the computer to learn
Sent from my HTC One using BimmerApp mobile app
1995 325i SOLD
umnitza exhaust
M3 bumper
Old 09-27-2013, 07:21 PM
if the cats are rattling then they're not functioning...replace them.
that my or may not affect the driveability concern, but should help greatly with emissions.
df
Old 09-27-2013, 10:46 PM
Mein Auto: 95 325i
Re: Failed smog!!!
df
Definitely replacing the cats, even just for the fact that my car is not breathing good at all!!
1995 325i SOLD
umnitza exhaust
M3 bumper
Old 09-28-2013, 12:30 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
Just wanted to say thanks for this...
your posts always contain a nugget of gold, DF..
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 09-29-2013, 02:14 PM
Mein Auto: BMW
Okay kids..
Im having a real pain smogging my E36 this year..
Last time it passed fine.
Running super clean at 25..
Running like a gross polluter at 15..
Installed stock exhaust, intake, & MAF.. to "un-modify" before smog test.
Would a Turner euro HFM chip throw it off that badly..?
I called Turner for some technical information and that failed..
I asked for their DME specialist and all he could tell me is "it dumps more fuel in there at idle".
Apparently "it dumps more fuel in there at idle" is as technical as the monkey at Turner could get.
I didnt know "dumps" was a standard unit for measurement.
Anyone have a STOCK chip for a Silver Label 413 ewsII DME?
Is it really time for a new CAT?
Im going to blow a can of sleaze-foam through the intake..
Im stumped fellas..
Old 09-29-2013, 04:34 PM
Mein Auto: 95 325i
Originally Posted by bmw-mania View Post
Okay kids..
Im stumped fellas..
I do have an extra silver label chip you could try if you like. My buddy did the seafoam thing on his 325i and after he did it his car passed! might work for you too.
btw i found magnaflow cats that will work on our car on amazon for REALLY cheap. havnt gotten them yet but after i get them installed and resmog ill let everyone know how they work.
I got the info from a guy that posted on bimmerforums about his smog problem, he actually had almost the same smog numbers i did and he installed these http://www.amazon.com/dp/B001P9RUU8/..._26725410_item
on his car and passed
Jason
1995 325i SOLD
umnitza exhaust
M3 bumper
Old 09-29-2013, 07:04 PM
Mein Auto: BMW
Jason,
Glad to hear it worked for your buddys e36.
Im hoping it helps with mine too.. *crossfingerslikeabigsissy*
That IS a PHENOMENAL PRICE for a new cat.. If I have to get new ones, I will be taking these into consideration.
Its looking like a new cat may be in my future.. drag
In my searches, the similar issues that others have experienced all point to a new cat. drag.
I would be interested in the chip as well.. If you are willing to part with it.
THNX & Cheers!
Old 10-09-2013, 04:22 PM
Mein Auto: 95 325i
Finally!!! new magnaflow cats installed and it passed smog!! i got a smoking deal on these magnaflow on amazon.com too! $70 a piece!! 2-1/2inch inlet and outlet and they are CARB approved. So apparently new cats was the problem.
I still feel like my idle to 4k rpm is absolutely gutless but it might just be me with the new cats the muffler shop redid the exhaust from where the exhaust manifolds piping comes together all the way to my umnitza cat bac system. they opened the exhaust piping up to 2-1/2inch so it breathes better. I was expecting a little better bottom end with some better flowing cats and exhaust... but instead it still feels gutless
Jason
1995 325i SOLD
umnitza exhaust
M3 bumper
Old 10-09-2013, 05:11 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
It passed even with the rattling VANOS? And don't you suppose the performance will get better when the new VANOS is installed?
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 10-09-2013, 05:29 PM
Mein Auto: 95 325i
Re: Failed smog!!!
Haha yeah the rattle isnt very noisey at idle and my exhaust almost over powers the vanos rattle at 2500rpms ..... If your in the car atleast lol
Well I'm not sure, the power loss I feel is from idle too 4k, and the vanos doesn't come into play until after 3500rpms right?
1995 325i SOLD
umnitza exhaust
M3 bumper
Old 10-09-2013, 07:35 PM
D'oh, You Kids!
Re: Failed smog!!!
If it's rattling at idle it's affecting it over the whole power band.
Quotes to live by:
BMW-CCA #441426
Old 10-09-2013, 08:20 PM
Mein Auto: 95 325i
Re: Failed smog!!!
Well then, I guess I'll find out how much a difference the new vanos will be lol
1995 325i SOLD
umnitza exhaust
M3 bumper
Old 10-10-2013, 09:13 AM
Mein Auto: BMW
Glad to hear it..
If I cant get her to smog today.. Ill be looking at a new cat.
Old 10-10-2013, 05:12 PM
Mein Auto: BMW
.. DAMMIT
Well...
I went to check my car again at the smog shop.. :angry:
my hc(ppm) is 675 at idle... max is 85 which would make my baby a gross polluter.
my hc(ppm) is 140 at rpm .. max is 50 " " "
C02% is 13.5% .. should be above 14.5%
C0% is .69
I seafoamed the intake this morning..
I did all the normal jaw flapping items.. good fuel, fuel filter, spark plugs, oil change (oil has 300mi now), fresh filter..
I even used a ahem.. Alternative Fuel additive..
smog guy says "buy a new cat"..
I guess its time... Is it time?
Any smog guys out there?
Cheers!
Old 10-10-2013, 06:54 PM
Mein Auto: 95 325i
.. DAMMIT
Well...
C0% is .69
Cheers!
Im no smog tech but i spoke to quite a few about my issue and showed them my smog numbers. They all said new cats would fix it... and they did!
I had horrible numbers just like you! My ppm was so far off i didnt think new cats could possibly change it but they did
Check out amazon for those magnaflow cats
http://www.amazon.com/Magnaflow-3400...ytic+converter
only 4 left!! and at that price i felt like it was worth it.... hell new bmw cats are $500++
1995 325i SOLD
umnitza exhaust
M3 bumper
Old 10-10-2013, 08:07 PM
Mein Auto: BMW
I still got that link from last time vmax.. thanks
So you were suffering from similar numbers.. ?
Ok.. thats good to know.
The only searches i found that fit my case are from saab forums.. :ohno:
Old 10-10-2013, 08:15 PM
Mein Auto: 95 325i
Yes, my ppm and my nox were off the charts high... i may as well have bolted a 800cc holley carb onto my intake
My money is on the cats being bad... pretty much the only thing i hadnt replaced when when i got it smogged and it made all the difference
1995 325i SOLD
umnitza exhaust
M3 bumper
Old 10-10-2013, 10:11 PM
Mein Auto: BMW
Ditto..
at least there is piece of mind knowing that everything else is up to snuff.
Cats it is.. FCK.
